looking for a thin fuel/gas tank?
Discussion in 'The Hokey Ass Message Board' started by adamsrotors, Jul 19, 2013.
  1. adamsrotors
    adamsrotors
    my 1951 pontiac's tank is on it's last legs, there are no repops/replacements, and I'm going even lower in the back and could use the clearance.
    I'm looking for another car's tank that would work...thin is key.
    ideally it would have side filler location so I can still use my factory fuel door, but if not I'll go up thru the trunk.
    anyone us another GM tank in their '49-52 pontiac?
    how about a particular mustang tank or other brand/model?
    any help would be great...
    looking for something quick, easy, affordable...and thin. something under 7" thick.
    ...and I'd be ok with as little as 10 gallons.
  2. good luck if you can go to a car show and just look under cars. Or try to find a shop that can make you one Good Luck.
  3. tfeverfred
    tfeverfred
    Find a parts store with an older model cross reference book.
  4. adamsrotors
    adamsrotors
    local parts store: "...what's a book?"
  5. adamsrotors
    adamsrotors
    uh...wut?
  6. tedley
    tedley
    from canada
    What size is the opening? Thin is not going to tell us much.
  7. tfeverfred
    tfeverfred
  8. tfeverfred
    tfeverfred
    It's what you ask the old guy for.
  9. ParkinsonSpeed
    ParkinsonSpeed
    I would summon a fabricator to make a copy of your tank minus the couple of inches clearance... Hell even make a template of the original tank for some of the guys that may be interested in making a new one....
  10. George/Maine
    George/Maine
    You could try 51 chevy 50 olds.I needed a tank for a 49 olds 98 and 50olds 88 fit but had the use fulnel ,fill tube was to short.
  11. INNOHRY
    INNOHRY
    A buddy of mine used a 1965 mustang tank in his 1952 Chevy. The spare tire well had to be removed, but it ended up being a slick install.
  12. iroc409
    iroc409
    How thin? What about Rotopax and some ingenuity? It's probably a bad idea, but they are thin.
  13. adamsrotors
    adamsrotors
  14. fleetside66
    fleetside66
    How about one of the 49-66 Chevy truck gas tanks that fit behind the seat? Check out the online catalogs from one of the aftermarket suppliers (like LMC) for dimensions. Maybe too wide?
