looking for adapters
Discussion in 'The Hokey Ass Message Board' started by corbincash, Feb 8, 2011.
  1. corbincash
    corbincash
    from ohio
    i searched and no help.
    i have a 29 model a with a mercury flat head thats gonna be a traditional 50s rod. i need some wheel adapters that are from mustang bolt pattern 5 on 4.5 to 5 on 5.5 so i can run the old 19 in car wire wheels. thanks
  2. alchemy
    alchemy
    If you want to build a traditional 50's rod, you should know the 19" wires were the first thing the guys threw away. Read some old magazines and you will see.
  3. Ricci32
    Ricci32
    I could use a set of adaptprs also mustang boltpattern to 40 ford. 5x4.5 to 5x 5.5 any help guys.
  4. corbincash
    corbincash
    from ohio
    yea the 15 inch steel wheels arent my style, too played out. i want it to add my own style in with it.
  5. You know what they say: "Google is your friend"! I was looking for wheel adapters to fit my '29 Chevy, typed in "wheel adapters" and found lots of sites. I even found 6-lug to 5-lug adapters!
    Good luck!
  6. Jalopy Joker
    Jalopy Joker
    search parts for sale here? place an ad in wanted section here?
  7. Retro Jim
    Retro Jim
    Do a search in the forsale parts section . There are some guys selling well adapter all the time on there .
    Are you really sure you want to go that route with those terrible 19" wire wheels ? Ever try to get a bicycle wire wheel to run true ? That should answer your question about not wanting to use 19" car spoke wheels !
    Retro Jim
  8. Dirty Dug
    Dirty Dug
    Most wheel adapters are 7" in diameter. That's too small for early ford wire wheels. And don't forget the inner support rings. I had a pair made that are 8" diameter, from wheeladapters.com. They weren't cheap.
  9. larry woods
    larry woods
    from venice fl
    i bought mine from summit. if you go online and spend some time(am an OF so it took me quite a while to find what i wanted). you will find just about any configuration. i went from 5.5 to 4.5. sorry i don't remember the mfg name.
  10. scrap metal 48
    scrap metal 48
    Go to ebay.. Should be able to get 1 1/4" wide in the bolt pattern you want for about $75.. I use them on S10 rear ends and run 16"x4 1/2" steelies on my model A coupes, perfect for fendered A's.. Never a problem if they are installed correctly........
  11. Crankhole
    Crankhole
    How does your Model A have a Mustang bolt pattern? Disc brakes? Those wires should fit stock hubs/drums.
  12. POD
    POD
    I bought some off ebay a few weeks ago for 60.00 including shipping.
  13. Andy
    Andy
    I have never looked at the 19" wires. I have made the support rings for the 18-16" wires when used on the 40-48 drums. I know that the inner hub lip of those wires sticks out and and that makes a really thick adapter needed for for clearance. A 1" wide adapter/spacer will work on a 8" Maverick rear. Not on a 9" because the drums are bigger. The fronts are really the problem if you want to use late drums or disks. The tires really stick out and it looks like fido's ass.
    You really need to mock it up to see how it all will look and what adapter thickness you need.
