1952-59 Ford Looking for an 8" rear for that 1952-56 Ford ?
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Apr 10, 2025.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. nosford
    nosford
    Jeff, it won't open for me, I have tried several times over the last few days. FYI
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    You might look it up by his name, Mike Ostrom it came from a 1972 Mustang complete from drum to drum located in Phoenix,AZ $300 badjoe.jpeg
    down-the-road and nosford like this.
  4. jimmy six
    jimmy six
    I think 1972’s are wider than the early Mustangs.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    In the listing he states it is 54" backing plate to backing plate, 61" from the outside of the drums. Measurements are in the "Sticky File" https://www.jalopyjournal.com/forum/threads/faq-sticky.897329/ See Post 9. Using later model Ford wheels that have more offset will gain you some room. You can compare that to the popular 8.8" specs here. https://www.therangerstation.com/tech/ford-8-8-inch-rear-axle-history-and-specs/#gsc.tab=0
  6. nosford
    nosford
    When I replaced the stock rear axle in my 55, the stock axle measured out at about 58" with the brake drums on at the wheel mounting surface. I used a Granada axle (was told it was a 1976) that measured the same 58" width. The spring perches were within a 1/4" and dropped onto my springs without modification. Needed new u bolts with longer thread as the old u bolts wouldn't tighten completely as the nuts bottomed on the thread. Easy bolt in. At 61" wide I think my 15X6 wheels would be rubbing the outer wheel well lip so too wide for me.
