Hot Rods looking for Black old school enamel
Discussion in 'The Hokey Ass Message Board' started by D.N.D., Feb 17, 2016.
  1. Atwater Mike
    Atwater Mike
    October of last year (4 months ago!) I went into Tractor Supply for some more single stage Valspar black. (I had been using it for a few years)
    The manager said the Valspar was all confi****ed by EPA ***s the week previous! (because it contained 'oil'!) It would be replaced with some water based 'enameloid'...
    So, be advised, fellow Californians...the Tractor Supply 'oil based Valspar' is gone.
    ...And here in Merced county, they are NOT as 'strict' as they are in L.A., S.F. Bay area, etc.
    WE used to be able to go East 20 miles to Mariposa County for lacquer. Wonder if they're still exempt from 'stupid'... I'll have to call. Ready to paint some running gear soon.
  2. dirt t
    dirt t
    The new normal?
  3. crminal
    crminal
    TSC oil Valspar replaced with Majic brand. Now uses a soy based oil.
  4. john worden
    john worden
    from iowa
    Since you're painting a custom framed scoot I would up your game and use a premium finish. Some if not all of the lower price generic blacks are too brown for my taste. I suggest 60's/70's BMW car Avus black in PPG, Glasurit, Sikkens etc. acrylic urethane single stage. GM has some black blacks as well. The cost will be high but you won't need that much. Any of these sprayed over a quality primer/sealer will be spectacular.
  5. Budget36
    Budget36
    We lost the Valspar here as well, I think you can still get real paint in Toulumne County.
  6. D.N.D.
    D.N.D.
    Hi John
    Boy thanks for bringing up the color range deal as I forgot about that all together, we would have really been bummed with a brown-black frame
    Maybe the ' Black Pigment ' is very costly so they leave a bit out in the tractor paints to keep the cost down ? LOL
    We will step up and buy the good stuff for the cool scoot project
    Don
  7. Enamel paint=instant gratification!
    AHotRod likes this.
  8. RainierHooker
    RainierHooker
    from Tacoma, WA
    Check out Interlux Brightside, it is a single stage, non-catalyst, alkyd enamel intended for marine applications and is available at boat-supply places like West Marine. Marine paints are not regulated the same as others, so it still has all that bad ol' stuff in it. It is intended to be "brushed and tipped" so it flows out supper nicely, but can be reduced and sprayed too. I'm using it on my Model A, and it, so far, has worked, and looked great.
    AHotRod and gwhite like this.
  9. gwhite
    gwhite
    SUPER MODERATOR
    Ditto. Also check out Kirby boat paint...they're an old company and have a number of vintage colors (if you decide you want to go that route)
    AHotRod likes this.
  10. D.N.D.
    D.N.D.
    Thanks again guys and I guess part of it depends if we can buy the stuff here in So-Cal, or if it can be shipped in and not be busted by the ' Paint Police ' and hauled off to the slammer
  11. dan r brooks
    dan r brooks
    what about por-15 products I have brushed it on and it flows out smooth .you can also spray it
  12. OLDSMAN
    OLDSMAN
    The problem with por-15 is that it has no UV protection in it. When used on anything that will get the sun rays it will chalk real bad. Yes it does flow out well you cant see brush marks at all. I used it on the frame for the 42 Chevy I am building, and was amazed at the results. Be careful using it though and on't get it on your skin, it is a ***** to get off. I had a hell of time with what dripped on my arms and wrists.
  13. 31 Chopped Coupe
    31 Chopped Coupe
    What type of respirator would be safe to use with the Majic enamel with reducer and hardener? I was planning to use this for my frame and axles.
  14. john worden
    john worden
    from iowa
    It's the isocyanates in the hardener that is the most dangerous. Filter labels state were they should be used. The paint suppliers usually sell respirators.
  15. slammed
    slammed
  16. crminal
    crminal
  17. Clik
    Clik
    I have already inhaled enough **** in my 62 years and don't need anymore. It looks like the big issue with Iso's and respirators is filter change. I DON'T plan to paint for a living and wonder if I change filters with every paint job can I get away without an air supplied respirator? I've also heard I will have to Vaseline my beard or shave (skeered of razors).
  18. AHotRod
    AHotRod
    So what did you end up using?
  19. DDDenny
    D.N.D. p***ed away last year.
    RIP Don.
  20. Kan Kustom
    Kan Kustom
    Dammit ! Every time I hear of losing another hot rod brother I feel like puking.
  21. Todd's Rod's
    Todd's Rod's
    from MInnesota
    go to your local PPG dealer and ask for ALK 200 in gloss black, a quart is enough to do your frame no hardener you can brush it on or spray watch out for over spray. it dries in about 15 minutes to the touch and is fully cured in 24 hours it last like powder coating.
