Looking for clutch pedal/linkage ideas for '32 Ford
Discussion in 'The Hokey Ass Message Board' started by lowrod, Dec 10, 2007.
  1. lowrod
    lowrod
    I'm looking for ideas for clutch/brake pedal and linkage for a '32 Ford frame. I'll be running a Muncie 4-speed, so I'm open to mechanical or hydraulic setups. If you have pics, that'll be great too.
  2. Here's what I did. Drilled and tapped the Scattershield bellhousing for a bracket and mounted a GM Clutch linkage ball, did the same thing on the frame side and then machined a cross shaft that uses the GM nylon clutch linkage ball bushings, countersunk into the cross shaft ends. I used 5/8 DOM tubing and drilled and tapped 3/8 NF for spherical rod ends (left & right) for the rods. I cut out the arms from 3/8 plate and welded them to the cross shaft. You will need to do a lot of measuring to get all of the dimensions correct and on the same plane, so the throw out arm works correctly.
    HemiDeuce.
    29EHV8 likes this.
  3. I have seen 40 ford brake and clutch pedals used on 32's. HRP
  4. Dice
    Dice
    from Marion, TX
    Man I like that pedal setup in the pic! Do you have an extra one laying around for me????
  5. Painterman
    Painterman
    That is absolutley beautiful! Makes the setup I came up with look downright crude!
  6. For those that asked for a couple more pictures.
    HemiDeuce.
  7. marodder62
    marodder62
    Were did you get the GM clutch linkage balls and nylon bushings? What year and model are they from?
    Thanks,
    Jerry
  8. alchemy
    alchemy
    Saw in the new Street Rodder magazine that SoCal is making a bellcrank and arms kit that looks like HemiDeuce's above. In the article they install it in a '32 frame with a SBC/Muncie. I wondered how come somebody hasn't offered this before? A lot of the parts might be from the GM shelves, but there are some critical lengths and angles in there too. If you're not a DIY fabricator, check it out.
  9. Anderson
    Anderson
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Hey Fidgiter..thanks you solved 2 problems for me on that one
  11. GassersGarage
    GassersGarage
    This is wilwoods reverse under dash mount..............
  12. Minewithnoshine
    Minewithnoshine
    You don't need a kit to build that setup at all. I used 51 F1 pedal assembly, an early GM bell crank assembly, some 3/8" heim/rod ends and some round rod threaded, I think the whole setup only cost me about $70-80 to make and works flawlessly, looks great too, I'll get a few pics of mine. Besides the pedal assembly and rod ends, the rest of the stuff can be sourced at a junk yard, no need to dish out crazy money to buy a pre-made setup.
  13. hot rod pro
    hot rod pro
    from spring tx.
    this is how we have done it in the past.hope it helps.
    -danny
  14. The GM part number for the Ball Stud is 03935289 and the seat number is 3743349, both are group 008510
    I can't find the number for the Clutch Fork, but note that it is not straight, it is a dog leg style.
    I also ended up putting a number of holes in the arms to change the ratio.
    HemiDeuce.
  15. Anderson
    Anderson
    I'd like to see pictures of that. I'm at this same spot in my build and would like to keep a mechanical clutch linkage if I can get away with it.
    The SoCal kit is expensive, but I bet they'll sell you one without the bellhousing.
  16. The So-Cal set-up uses a clutch fork that is a Danchuk re-po part for 55-57 chevys. It costs about $40.00. It looks similar to what hemi-duece used.
    I have used the So-Cal clutch set-up. It costs about $250.00 and comes with everything but the clutch fork.
    I was happy with the way it worked and looked.
  17. marodder62
    marodder62
    Thanks HemiDeuce. I'll probably go with the 57 Chevy clutch fork since it looks similar to what you used.
    You put holes in the arms coming off the cross shaft? I wasn't aware that you could change the ratio that way.
