Looking for someone who does custom speedometer cables. preferably someone in North Carolina. also looking for someone to recreate some high and low side ac lines.
check your local commercial truck service center, if they work on refer trucks, they should have hose and fittings to make your a/c lines, and are usually much cheaper then a hot rod a/c dealer..........
Just a warning: if you crimp A/C lines with a crimper intended for hydraulic hose you are likely to get a leak. I risked it on my car and after a year one line did, in fact, start a slow leak. Every spring I throw in a can of R-34 and the ac works all summer but still, leaking is never a good thing.
