Looking for Ford Big Truck Brake Return Springs
Discussion in 'The Hokey Ass Message Board' started by Sleeper-6, Feb 12, 2010.
  1. Sleeper-6
    Sleeper-6
    I'm hunting down parts again and could use a little help. Can anyone point me in the right direction to find the brake return springs for a 37 Ford Big Truck (model 79) with mechanical brakes? I tried a set of car springs but the hooks were too short and interfered with the shoes.
  2. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    post a pic with some measurements or send me a P.M. if you can. i've got a boatload of truck service parts. i may be able to help.
  3. Sleeper-6
    Sleeper-6
    Will do, I'll take a few pics tonight. Thanks.
  4. barry wny
    barry wny
    The 1 ton was the same front axle and back plate as car/pickup just different hubs. But the rear like you probably have was Timken split in the center and all was different. Wheel seals were impossable to find with dimensions, Dick Spadaro http://www.dickspadaro.com/ saved the day, and probably can help you. I know I have used stuff around but could only identify with pics/dimensions
  5. Sleeper-6
    Sleeper-6
    This truck is 2-ton with a full floating rear axle. the front and rear brakes are identical except for the emergency brake hardware on the rear. Here are some pics of the springs.
  6. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    I'll check tomorrow. all this stuff is at the shop.
  7. Sleeper-6
    Sleeper-6
    I found some more info. Here is the part number I believe I need, Ford #51-2036.
  8. Have you tried JOBLOT in Queens? They might have a cross-over # ,,,,800-221-0172
