Technical Looking for info on T5 manual transmissions
Discussion in 'The Hokey Ass Message Board' started by Colton Bates, Sep 14, 2020.
  1. Colton Bates
    Colton Bates
    Have a transmission I'm looking at and wondering if I can get some knowledge from anyone on here. Transmission is off a 2.2 said to be in working order. Thanks for your help.
  2. tjm73
    tjm73
  3. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Buy this book on Amazon.....everything you need to know is in there.
  4. ididntdoit1960
    ididntdoit1960
    from Western MA
    just google the tag number - info will come up - oddly enough, I get a lot of my t5 info from BritishV8.org
    sko_ford and Hnstray like this.
  5. bobscogin
    bobscogin
    If you mean 2.2L 4 cylinder as used in the S-10 from '93 and newer, it's World Cl*** and has a Ford mounting pattern. Not sure if that matters to you, but it's worth knowing.
    Bob
    zorro4153 likes this.
  6. gimpyshotrods
    gimpyshotrods
    That transmission has a few features that makes it less favorable.
    It has an electronic speedometer drive.
    It has the lower 4.03:1 first gear ratio set. This was needed to get a heavy S10 moving with a small engine. In a lightweight hot rod, it is almost too low to be useful, and there is a big step between 1st and 2nd gears.
  7. Hnstray
    Hnstray
    from Quincy, IL
    This website has an excellent listing of all production variations of the T-5 offering info tag Model #, whether World Cl***/Non-World Cl***, gear ratios and OEM application.
    Ray
  8. Shawn Wildman
    Shawn Wildman
    bchctybob likes this.
  9. Rand Man
    Rand Man
    I’m going to look thru this thread but have a question. My T5 is having trouble downshifting. Took it to a transmission shop. He says it is not a a “world cl***” T5, and they no longer manufacture replacement parts for this particular trans. That’s kinda hard to believe. Does anyone know of a source for parts to rebuild an older T5?
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
    Or most transmission parts places.
    https://m.thegearbox.org/catalog/item/3819132/3532008.htm
    Sent from my SM-G973U using The H.A.M.B. mobile app
  11. Marty Vanin
    Marty Vanin
    the gearbox.org has parts for both generation T5 .First time I’ve heard that parts for non world cl*** were not available
  12. Marty Vanin
    Marty Vanin
    Johnboy 34 is faster than me
  13. LS1
    LS1
    from us
    Check out hanlonmotorsports.com for T-5 parts - I had Bob Hanlon rebuild one of my world cl*** T-5's.
  14. Rand Man
    Rand Man
    Update: my transmission guy says it’s not the general rebuild parts (synchro and seals) he can’t find, it’s the main parts like the shafts and gears. So I’m looking for another NWC T5. Message me if you have an S-10 or or one that has similar length shafts.
  15. gimpyshotrods
    gimpyshotrods
    You can buy all of that on eBay.
    warhorseracing likes this.
  16. CyaNide
    CyaNide
    from Texas
    Need to find a better transmission guy.
    CN
    gimpyshotrods likes this.
  17. warhorseracing
    warhorseracing
    from cameron wv
    I think you need to find a new transmission guy as the one you have doesn't want to work on yours. Learn to do it yourself. Not hard and there are numerous tutorials on line. If you do run into trouble you will have all of the parts your trans guy can't get and lay them all on his bench.
  18. gimpyshotrods
    gimpyshotrods
    I guess your transmission guy has enough money.
  19. Montana1
    Montana1
    ekimneirbo likes this.
  20. Rand Man
    Rand Man
    Hey, it looks like Astro Performance is going out of business. Their website is down and and some have posted on other forums recently, that orders aren’t being filled.
    Is there another way to get parts for a non-world cl*** T5? Not the synchros and gaskets, gears and shafts.
    Montana1 and Hnstray like this.
  21. Rand Man
    Rand Man
    I just talked to Texas Drivetrain performance. Seems like a nice guy and knowledgeable. Said they did a lot of work for Astro in the past and can make or possibly repair my parts.
    I may be on track to get this thing fixed.
    Hnstray likes this.
  22. Grease348
    Grease348
    I got a donor t5 out of a camaro and swapped everything into the s10 case for better gear ratios
  23. Rand Man
    Rand Man
    I am interested in that swap. Is there a big trick to it?
  24. krylon32
    krylon32
    from Nebraska
    The parts are getting scarce. Cores for manual speedo trans have just about dried up. I currently have 4 S10 T5 trans being done for my customers with several others pending. It takes patience to build these as some of our parts are coming out of CA and there's been delays. My trans guy always comes thru but it takes time.
  25. Ziggster
    Ziggster
    When I was looking for mine a couple years ago, there was s steady supply on kijiji (Canada’s version of Craigs List). I picked up two, and parts for a third from a guy getting rid of hus stash for CAN$250. I think I might even have the S10 case. Too bad I’m north of the border. I found this site useful as well as the British site previously mentioned to help identify stuff.
    https://lugnutz65chevystepside.weebly.com/t5-info-page.html
  26. grumpy65
    grumpy65
    Hnstray likes this.
