just wondering if anyone might be able to help. It's for a 3.5" bore, and the upper rings have to be 1/16" There seems to be tons of 5/64". only need enough for a 4 cyl. you ask what are they for...guess i'm prepaired for gettin some shit, it's for a 140cid vega motor. stock rings are 5/64, but these are TRW pistons..12.1 comp. I've checked with summit and jegs, no luck local speed shop no luck, just figured i'd check here. thanks
PBR just go walk down the street and knock on the door at harley. I believe those rings a .062 and the oil ring is .158 at standard bore, 3.498
Also Hastings rings Part # 7002 1/16-1/16-5/32 torsional compresional cut rings. http://www.hastingsmfg.com/catalog/catdiar.asp
