Hot Rods Looking for rad suggestions....or tips
Discussion in 'The Hokey Ass Message Board' started by movingviolation, Sep 9, 2009.
  1. movingviolation
    movingviolation
    Well, after farting around with the Rpu for a bit i put the 32 shell in place...inorder to get the right line from the cowl to the shell i'm looking at around 16 1/2 to 17 inch height.... max! Any tips on what may fit in there and look right?
    Thanks
  2. Oh I thought you ment I should suggestion Rad and I was gonna tell you to get a mohawk.
    Don't know what it needs to cool but the radiator from a Willys/Overland will fit in there real well, they were commonly used way back when. Don't think it will cool a blown 392 but it should do alright with most standard motors. I also don't know how you're set up but a lot of fellas used to move 'em forward and drop them in front of and below tjhe cross mamber.
  3. E Burfield
    E Burfield
    Call a good radiator shop. Ask the to make you a radiator useing the right top and bottom tanks. step up and spend the money. you'll be happer in the long run.
  4. Ruiner
    Ruiner
    Whippet...Whippet good...hehehe...
  5. Duece's wild
    Duece's wild
    Might help if I knew what a Rpu is?
  6. yekoms
    yekoms
    Rpu = roadster pick up
