Hot Rods Looking for some buick Gurus!?
Discussion in 'The Hokey Ass Message Board' started by punchdrunk, Apr 23, 2014.
  1. punchdrunk
    punchdrunk
    from las vegas
    W*** sup fellas, I'm needing help with a 54 buick roadmaster I have I've just started messing with it would like to see if it runs. I've checked for spark and it has spark I've sprayed gas down the carb and connected the fuel pump hose to clean gas container it's just turns over about 3 to 4 times and its like it will get stuck it will stop I'll try again and it does the same thing what could this mean? im using a charged up battery and keep the charger on it to keep it charged also the engine is a 322 nailhead motor. I've checked the firing order and it seems good so I'm not sure if its cus it's been sitting so long the engine gets stuck after a couple cranks.
  2. lostmind
    lostmind
    water In the cylinders?
  3. jetnow1
    jetnow1
    from CT
    Try pulling all the plugs and see if it turns over better, put some light oil in each cyl to help lubricate the rings. If this helps then reinstall the plugs and try it. If it does not help
    then it sounds like perhaps broken rings getting jammed.
  4. justold
    justold
    x2 . if it still bites back , remove the coil wire if that helps try retarding the timing a little . [ rotate the distributor in the rotation of the rotor .]
  5. tommyduncan
    tommyduncan
    I would check the condition of the battery cables and the wire to the starter. If it isn't getting full juice it won't crank it long.
    If it's been sitting a long time the fuel pump is probably toast. I rigged up a jerry can with a Schrader valve to push fuel into the carb for these situations.
    I have a 55 Super with the same motor and I live in Henderson.
  6. punchdrunk
    punchdrunk
    from las vegas
    Ima try this out till hopefully the rings aren't Brocken
    Cool thanks even if the fuel pump didn't work I figuired it would still try and start while pouring little gas to the carb right
