Technical Looking for unusual fitting
Discussion in 'The Hokey Ass Message Board' started by chopolds, Feb 14, 2025.
  1. chopolds
    chopolds
    from howell, nj
    OK, I get frustrated when the media in my gl*** beading booth, gets stuck in the corners and doesn't' flow down to the bottom, where the pick-up is. I even got the ******** motor that Eastwood sells, but it doesn't work very well.
    So i had the idea to put some 1/4" tubing around the upper perimeter of the booth, just under the floor. Fittings at each corner, with a tube pointing down, to blow the media to the bottom. Only problem Is, I can't find a "T" that is 90* with another port pointing down. All I can find are fittings looking like a T. Anyone know if there is a place that makes T's like this?
  2. Oneball
    Oneball
    Corner tee is what you’re looking for.
    69fury, Tow Truck Tom, TA DAD and 4 others like this.
  3. guthriesmith
    guthriesmith
    I ***ume you mean that the two ports that are 90 degree to each other are in one plane and the third port is in another basically making a “corner”.
    Tow Truck Tom likes this.
  4. guthriesmith
    guthriesmith
    I typed too slow…
    Tow Truck Tom and Sharpone like this.
  5. GTS225
    GTS225
    Buuttt....it sounds like he's looking for a corner T in 1/4" compression fitting. Not so certain one can find that. What's being shown is for pipe sizes and perhaps conduit. I know they're also made in PVC for fresh water plumbing, but again, for 1/2" and larger pipe.
    Just an observation.....Roger
  6. Joe H
    Joe H
    With some copper tubing, a saw, a torch, and some solder, you should be able to make any type of junction you need. It won't have any pressure on it and you can custom fit it to the box. Crimp the ends down to form nozzles on the four drop down legs. Diameter is not to critical, 1/4" should be enough to blow beads arounds.
    Algoma56, alanp561 and guthriesmith like this.
  7. As @Joe H says you can make your own, even use water cooler feed line in plastic.
  8. 26Troadster
    26Troadster
  9. squirrel
    just drill a hole in the "bottom" of a normal elbow, for the downward blowing air jet.
  10. DDDenny
    Does it need to be 1/4" or metal?
    Simple PVC glued together might work, some are available with threads they also make PVC pipe adapters.
    If pressure is required, smaller PEX lines with these fittings might work.
    https://www.homedepot.com/p/PLUMBFL...For-Use-in-Pex-A-Tubing-XQUF0038-OM/326958411
    Search
    Here:
    https://www.google.com/search?clien...HVT7CSwQtKgLegQIERAB&biw=1280&bih=800&dpr=1.5
    Have you heard of Sharkbite PEX plumbing hardware?
    https://www.google.com/search?clien...HeBNECMQtKgLegQIFRAB&biw=1280&bih=800&dpr=1.5
