Hot Rods Looky what I found...
Discussion in 'The Hokey Ass Message Board' started by CBurne7, Feb 10, 2016.
  1. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Here is what happened to one of my old dry rotted tires I was using as a roller with the car just sitting in my garage. In other words, I wouldn't run them....
  2. Dapostman
    Dapostman
    Blowouts were a lot more common before tubeless tires were common. That tube doesn’t hold much pressure without the tire around it.
  3. steinauge
    steinauge
    from 1960
    The only tires I have ever had come apart like the one in the picture were radials.
  4. 50dodge4x4
    50dodge4x4
    You have been fortunate! I've seen more bias ply tube type tires blow out then I have seen radial tires blow out. But then again, I worked in a gas station before radials were introduced to the general public, around 72-73.
    The love and trust for bias ply tires is greatly unfounded, there are many reasons tires went to the radial design. A dry rotted tire is junk, regardless of what design or manufacturer's name it has, its only a matter of time. Gene
  5. Nailhead Jason
    Nailhead Jason
    Clean them up and display them in you living room. Chicks love that kind of decore!
  6. BigDogSS
    BigDogSS
    from SoCal
    Tip one of them on its side and put a piece of gl*** on top if it and --> BOOM! --> new coffee table!
  7. CBurne7
    CBurne7
    Is the 'boom' the sound of the tire exploding? I'm not sure if they would be able to handle such a large load.
