Technical Loss all power overnight
Discussion in 'The Hokey Ass Message Board' started by Babyboomerboy, May 10, 2024.
  1. Babyboomerboy
    Babyboomerboy
    Got a problem that I hope some of you can help me with. Yesterday I turned on the key of my 1950 Ford Tudor V8, and pressed the ****on and the car cranked until it started. I just installed a new choke cable and I wanted to make sure it worked properly. Today I go out to start the car and nothing, nada. I not only could not get any response to turning on the key and pressing the ****on, my lights don’t work any longer. I put the battery charger on the battery and it read 6.3, so the battery is not the problem. What could cause a sudden loss of power? Thank you
  2. squirrel
    turn on the headlights, use your volt meter to follow the voltage from the battery to the headlights...where it goes away, that's the problem.
    Tow Truck Tom, Mr48chev and hrm2k like this.
  3. manyolcars
    manyolcars
    dirty battery terminals or any bad connection, specially the ground connections
  4. dwollam
    dwollam
    I agree with @manyolcars . Clean the battery terminals. I replaced the starter on my '36 Dodge pickup because it acted like it was dragging and wouldn't start, only to find new one did the same! Dirty terminals on battery under the floorboards.
    Dave
  5. Dan Hay
    Dan Hay
    A mouse? Bad connection somewhere, get out the test light and get comfortable.
  6. IIRC, the horn relay is the first connection in the circuit going to the ignition switch/headlight switch. Start there.
  7. RodStRace
    RodStRace
    and when we say battery terminals, it means BOTH ends.
  8. Babyboomerboy
    Babyboomerboy
    Thanks, I'll start by cleaning the terminal posts and cables and see if that was the problem.
    Tow Truck Tom likes this.
  9. squirrel
    yeah, fixing random things is so much easier than finding out what the problem really is....
    427 sleeper, jaracer and 57 Fargo like this.
  10. Dave Mc
    Dave Mc
    Ammeter maybe ?
  11. millersgarage
    millersgarage
    it's a ground, it's always a ground
    lowrd, Tow Truck Tom, e1956v and 3 others like this.
  12. garyf
    garyf
    You were attempting to rewire this car recently,is the wiring new ?
  13. Babyboomerboy
    Babyboomerboy
    Not under the dash. I rewired the headlights and parking lights. That was why I knew something was wrong when not only did the car not start but I lost the headlights also. After I rewired the headlights I checked them with the dimmer switch and it switched from hi beam to low beam so I figured I had a good circuit that far.
  14. ClayMart
    ClayMart
    Check the routing of your recently installed choke cable. Make sure something hasn't gotten grounded or shorted under the dash or underhood. Had any previous issues with blown fuses?
    bobss396 and RMR&C like this.
  15. jaracer
    jaracer
    Amen!
  16. Babyboomerboy
    Babyboomerboy
    Thank you guys very much. I removed both battery cables and cleaned both ends. Put it back together and the car fired right up. Thanks again
    Tow Truck Tom, Speccie, winr and 5 others like this.
  17. hepme
    hepme
    I was thinking damm sneaky rats!!
  18. I thought "It's always a F*N Dodge"!.....I'm confused.....
    (but you are right!)
  19. Except when it ISN'T! Mine turned out to be the POS. Corroded and loose. inside the cable end.
    Ben
  20. Mr48chev
    There ya go, I've got one out here that is playing the some times I will and some times I won't starting game that I need to do the same thing on.
    RodStRace likes this.
  21. dwollam
    dwollam
    Well @firstinsteele , in this case if his car is still 6 volt the ground IS positive! :)
    Dave
  22. Always start with the first dumb thing you can think of. Bad battery, loose/dirty terminals, bad ground for that circuit, etc. I lost count of the times I have read about someone ripping out the wiring or doing major surgery to the system and still having the same problem, when it was actually a bad fuse or bulb holder.
  23. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Something about this time of year makes battery terminal ends get all funky and interupt the flow.
    No joke, for a couple years I ran for THE auto club.
    Spring time was always busy with no start calls. ( Points and Carbs )
    No jump required.
    The easy fix remedy brought a $3 to $5 tip.
  24. bobss396
    bobss396
    Beat me to it. I know someone with a similar issue with something contacting the clutch pedal arm. Push in the clutch pedal and the truck died.
