loss of power when warm
Discussion in 'The Hokey Ass Message Board' started by Rick Thompson, Dec 3, 2008.
  1. Rick Thompson
    Rick Thompson
    Alliance Vendor
    I hope you guys can help, I have a 350 chevy with 9.5 to 1 compression, 2.02 heads, HEI dist., 600 cfm carb and a lumpy street cam. it runs very strong when cold (under 190) but as soon as it gets up to operating temp the power falls off at the lower end (1,500- 3,500 rpm). i should mention that the trans is a 350 turbo hydro with a 3500 stall
  2. if 190 is cold , what do you consider operating temperature?
  3. Rick Thompson
    Rick Thompson
    Alliance Vendor
    190-195
  4. that doesn't sound too warm. out of curiosity , what 600 edelbrock are you using , 1405 manual choke or 1406 electric choke? the 1406 is calibrated leaner
    i'd be tempted to try an insulator spacer between the carb and intake
  5. Rick Thompson
    Rick Thompson
    Alliance Vendor
    1405 manual choke and I am running a 1 inch spacer
