Technical Lost brake pressure during cold temperature
Discussion in 'The Hokey Ass Message Board' started by Petejoe, Oct 31, 2023.
  1. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve never experienced this before.
    This morning temperatures in Ohio was in the mid 20’s when I jumped into the 34 pickup. Stepped on the brake and lost all brake pressure. This has a single pot master cylinder running 40’s brakes.
    I continued down the country road warming the engine and pumping the brakes. As the engine and brakes warmed up my brakes returned to normal to finish the 20 mile trip. My brake fluid is full.
    I’m not running pressure relief valve.
    Would a brake pressure relief help??
  2. jaracer
    jaracer
    By "lost all brake pressure", do you mean the pedal went to the floor? If that's so, I think the cup in the master cylinder is old and very hard. I believe a master cylinder rebuild or replacement is in your future.
  3. BJR
    BJR
    Yup what he said.
    Petejoe and seb fontana like this.
  4. Happydaze
    Happydaze
    Never heard of that one before! Water laden brake fluid freezing? That's just a wild guess!!
    Chris
  5. '29 Gizmo
    '29 Gizmo
    from UK
    What fluid are you using?
  6. With no fluid loss I would suspect that the master cylinder seals shrunk and was byp***ing internally. Then when they warmed up they started to seal again ????
    Petejoe and Johnny Gee like this.
  7. Yup, in years past when working on cars with single master cylinder they often would show signs of failure (pedal sinking) when the weather turned cold. Dual masters will too, but I experienced more with single cylinders. :confused: Worn / hard cylinder rubbers don't seal well when cold. Time for some new parts.
    chevyfordman and Petejoe like this.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Ok thank you guys!!
    It’s was a NOS master installed a few years ago. The hardened rubbers in the cold has to be the problem.
    Thank you.
    On the way home my banjo growled a bit and I totally lost gearing to the rear axle. Had to tow it home. Ain’t old cars fun!!!
    mrfliboy and partsdawg like this.
  9. Bentrodder
    Bentrodder
    from Cotati
    Sounds like your pickup doesn't like the cold. It might be happier in CA with me.:D
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Brake fluid too thin
    Gear lube too thick
    Petejoe likes this.
  11. chicken
    chicken
    from Kansas
    Switch em! ;)
    Johnny Gee, Petejoe and Tman like this.
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    :confused:
    That’s where this pickup started originally.
    From there to Texas and then it was a partial basket case to Ohio.
    Time to pull the rear end, at least I’ll have plenty of room to pull the master cylinder. :confused::)
    Thanks again!
    Hellbentrodder likes this.
  13. chevyfordman
    chevyfordman
    I've had the same problem with my 48, usually bleeding the left front restores the brakes. I still haven't figured it out but then I'm not changing any parts either.
