Lost vin plate
Discussion in 'The Hokey Ass Message Board' started by bburge, May 5, 2011.
  1. bburge
    bburge
    Hi my name is Brian Im putting my 56 f100 ford back together to sell and noticed I misplaced the orginal vin plate. I was told that you are able to get the vin from the frame does anyone know where I can find it?:confused:
  2. hotroddon
    hotroddon
    They were in the glove box as well as on the top of the frame rails. I have seen them both on the driver's side right in front of the firewall, and on the p*** side closer to the motor mounts.
  3. Abomination
    Abomination
  4. bburge
    bburge
    thanks you guys I'll look
    Brian
  5. Larry T
    Larry T
    P***enger side, on top of the frame rail, right in front of the cowl.
    Larry T
  6. big creep
    big creep
    do you have the ***le for it? the vin is usually on the ***le.
  7. sociallydistorted
    sociallydistorted
    The exact same thing happened with my '54 a few years ago. Larry T is exactly correct. I just had to do a little surface rust-busting it was on the p***enger side frame rail.
