Projects Love it or hate it ... but here's my version of the T Modified
Discussion in 'The Hokey Ass Message Board' started by k1w1rodder, Mar 11, 2013.
  1. k1w1rodder
    k1w1rodder
    I started with stalled project I picked up,
    It required a new ch***is and I didn't want the pinto motor that came with it. I had ideas of doing something a little different, (ideas I got from the Hamb) So we went with a 1/4 eliptic front end set up
    From there we picked up a donor car to supply all the goodies. Remember this is a budget build.
    Everything that was useable was stripped out. The diff went under the back end with a model a rear spring
    The four bars were fabricated in my spare time at work
    Engine mounts
    Cross member and drive shaft loop
    I do a little hobby casting so I made a few bits and bobs to make the build a bit more unique
    Petrol tank is an old Dodge unit
    Every thing was fabricated and painted in my 30 x 30 shed and carport
    headlights are Guide units
    more to follow:D
    rbrewer and kiwijeff like this.
  2. volvobrynk
    volvobrynk
    from Denmark
    I love when a car gets De-ratted! You are on the right way!
    Post more please!
    It dont look good design wise, but I Think it look like you going the right way, so please dont let me down, and go street rod.
  3. k1w1rodder
    k1w1rodder
    donor steering column
    steering box is HQ Holden cross steer
    from paint to re***embly
    front wheels are getting swopped
    Now don't flame my diff cover...it was done to try and get the diff looking more central due to off set pumpkin. I know it doesn't look as good as the real thing but it is completely home built and..... i like it!
    From here it was body time. Now I know it gl***......trying to find steel down here is like trying to find rocking horse sh!t. It was framed out, stretched, with opening doors. beggars can't be choosers so I left it as it was.
    Ch***is colour is Milk Chocolate,body colour is Dutch White. Oh motor is 308 Holden, Edlebrock manifold and four barrel, box is just a trimatic
    more to come:eek:
    kiwijeff likes this.
  4. krazee
    krazee
    Where did you get the 1/4 eliptic's from?
  5. k1w1rodder
    k1w1rodder
    Snells in Auckland made the springs to my specs and I fab'ed the mounting brackets with adjustable height.
  6. SwedeVedette
    SwedeVedette
    Looks like a great start!
  7. The Bronze
    The Bronze
    I like the white/brown combo. Would look good with a bit of pinstriping.
    O/T, but did you make your own furnace for casting? is it an old LPG bottle then cement lined and running off gas? I've been looking at plans for a 'flowerpot furnace' to do a couple of things but yours looks pretty sweet, especially the swing-away lid set-up.
  8. Moedog07
    Moedog07
    What engine and transmission is that?
  9. Sphynx
    Sphynx
    from Central Fl
    I think we can all apreciate a budget build. Besides it looks like your havinf fun and well on your way to a fun ride. Keep posting looks good so far.
  10. GassersGarage
    GassersGarage
    I like it but where is the land of the long white cloud?
  11. raidmagic
    raidmagic
    Post 3 says it's a Holden 308
  12. volvobrynk
    volvobrynk
    from Denmark
    The steering wheel on the wrong side should be a clue!
    So is the mill, Holden 308.
    My Best gez is NZ. :) and I'm semi-stupid LOL
  13. That would look great with a DuVal style windscreen, I'm sure you could make your own!
    Keep going, that is one of the best looking budget builds going, even if it is tupperware (For now).
    G***ersGarage, the Land of the Long White Cloud is New Zealand.
    Doc.
    Edit: Good guess Volvobrynk, I don't think you are that stupid at all!!
  14. Nice work, K1W1. Been a while since i caught up with ur progress. Ive had a few 308 Holdens, and they go well. G***erG, the land of the long white cloud is English translation for Aotearoa, which is the Maori name for New Zealand.
  15. steel rebel
    steel rebel
    I like it! And for all those guys and gals out there asking how to build a low buck rod just keep up with this build. Keep posting pictures. I'm watching and waiting. I started the same way (not much money) and later when I started making more the finish will come.
    Gary
  16. MikeRose
    MikeRose
    from Yuma, AZ
    Looks great.
  17. ESGEE
    ESGEE
    from Sweden
    Looking good, looking forward to see it finished...
  18. tfeverfred
    tfeverfred
    Looks like a great build. I get what you said about the cover you made for the rearend pumpkin, but unless it really bothers you, maybe you should lose it. Most, if not all, hotrodders would understand the off set pumpkin. There's no need to try and disguise it.
    I like the color combination you're going with. And I like that you're keeping things simple. Just like a modified should be.
  19. raidmagic
    raidmagic
    in the first post he states it's an old Dodge unit
  20. K1W1, whats your motometer off? I like it, but dont recognise it.
  21. MikeRose
    MikeRose
    from Yuma, AZ
    Thanks. I didn't see it between the pics. Cool looking tank.
  22. hugh m
    hugh m
    from ct.
    Nice job...but it looks like some of your photos got reversed....
  23. Kevin Lee
    Kevin Lee
    Super Moderator
    Yup, I would never sweat you for using a fibergl*** body. Or odd steering, rear end, etc. given the cir***stances. And I'm even willing to give a p*** for the radials since proper bias ply tires are probably expensive to ship.
    But... that fake cover has to go. I know I would want friends to call me out for anything similar.
  24. k1w1rodder
    k1w1rodder
    Yes but it's 1 1/2 old gas cyl to make it a bit taller. I cut one in 1/2 and then took a 6 inch slice out of another and welded together.
    And yes pinstripping is on the cards for later.
  25. k1w1rodder
    k1w1rodder
    Hey Jeff thats another little casting project, wings are copied from a piece a friend had and the rest I made.
  26. k1w1rodder
    k1w1rodder
    Quick up date...
    ahhhh :mad: the thought of tackling the wiring job :mad::confused::mad:
    measuring up and making a template for the windscreen gl***
    and lastly view from the drivers seat and my new front wheels and tyres
  27. woodbutcher
    woodbutcher
    Hi K1W1.Know what you mean by "low buck".Seems like that describes my entire life.Hehehe.Love the build,AND the colors.
    Good luck.Have fun.Be safe.
    Leo
  28. kenji
    kenji
    Love it! You have a good eye for design.
    I'm heading to NZ this weekend. Know of a mid-30's Morris 8 for sale...or possibly a Ford Model Y or Model C?
    Ken
  29. k1w1rodder
    k1w1rodder
    ^^^^nothing that I'm aware of
  30. slimpick
    slimpick
    Nice trans crossmember. Should stiffen up the frame.
