Technical Love Joy shock conversion for Fords
Discussion in 'Traditional Hot Rods' started by EmperorOfWestVirginia, Dec 5, 2020.
  1. Has anyone here ever rebuilt a set of Delco Love-Joy knee shocks for a late 30’s early 40’s Ford.
    Trying to figure out how to how to remove the shaft and lever arm from the shock. These particular units don’t have the set screw/bolt.
    lothiandon1940 likes this.
  2. lothiandon1940
    lothiandon1940
    Back up for the Emperor.:D
    VANDENPLAS likes this.
  3. 62pan
    62pan
    I tried to but the splines on the shaft were so tight that I ended up busting the housing. I did manage to press the shaft apart after I broke it but even that was difficult. I had another pair so just cleaned them up and didn't replace the shaft seal. These are top fill so I run the oil only to the bottom of the shaft. Seems to work ok. That is only a leather seal and there was a company that rebuilt them but they modified the shaft and seal to make it easier but the cost was not for me. 20180818_163941.jpg
  4. Ned Ludd
    Ned Ludd
  5. brading
    brading
    When that type of lever shock got worn we used to put gear oil in them to stiffen them up. If there's no set screw/bolt what hold the shaft in.
  6. brading
    brading
