LOVELY NAILHEAD - separating trans help please
Discussion in 'Traditional Hot Rods' started by 345, Sep 7, 2014.
  1. 345
    345
    from Michigan
    Any ideas what I'm missing? I have only managed to part the Dynaflow about 3/4 inch from the engine after about 2 hours last night and then a few hours this morning?
  2. jr9162
    jr9162
    Did you take the inspection plate off the bottom of the bellhousing and remove the torque converter to flexplate bolts? Did you remove the starter?
  3. 345
    345
    from Michigan
    Did all that except the 3 flex plate bolts! Bingo!
    Thanks
  4. Fr. Buick
    Fr. Buick
    Check clearances on that flex-plate if you plan on using it again. When out of shape, it can ruin the Dynaflow.
  5. 345
    345
    from Michigan
    Thanks Fr.Buick!!
