Low buck split manifold for Chevy in-line 6
Discussion in 'The Hokey Ass Message Board' started by henryj429, May 27, 2009.
  1. henryj429
    henryj429
    Here's an el-cheapo way to get a cool sounding split manifold on your 194/230/250/292............
    First cut a hold in the bottom of the manifold. A plasma cutter works good, then use a die grinder to trim:
    Using a piece of stell pipe from the plumbing section of your locl hardware store, craete the second outlet pipe with integral splitter. Then make a flange from 3/8 plate, machine in the feature for the exhaust donut and weld in some studs:
    This picture shows the function of the splitter to divide the flow. It's not an exact fit, but it makes sense to allow a little cross-flow to balance the back-pressure in the two halves of the manifold.
    Finally, a little TIG welding. I must confess that I enlisted the help of master welder "Chops" for this, so I don't know the deatils of the rod he used. Anyway, here's the finished product. Total cost $30 and that includes having a local shop grind the mating flange face flat.
    Timmyd likes this.
  2. cooool!! what size pipe did you use?
  3. poofus1929
    poofus1929
    from So Cal
  4. henryj429
    henryj429
    The pipe I used is 1 5/8" ID and 1 7/8" OD. This was just right. Any larger and the joint with the manifold wouldn't work out near as clean.
  5. That's a great idea. Have you run it on the car yet? Todd
  6. StefanS
    StefanS
    from Maryland
    Anybody willing to do this for a fella who doesn't weld?
  7. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Very cool tech! Is it tech week yet?
  8. butcherted
    butcherted
    from hagerstown
  9. oldolds
    oldolds
    That is the traditional way to do it!
  10. Hnstray
    Hnstray
    from Quincy, IL
    The 'splitter' is what sets this apart..........very clever and well executed.
  11. 55 dude
    55 dude
    old thread good tech!
  12. Rusty O'Toole
    Rusty O'Toole
    Good idea, one suggestion, you don't have to make your own flange. You can buy them at any muffler shop.
  13. StefanS
    StefanS
    from Maryland
    Here we go... 20170412_121207.jpg Flange from another manifold cut off. 20170413_165744.jpg Front half of manifold completely separated from rear. 20170413_165820.jpg And the heat riser still works for those cold Md. mornings
    turboroadster likes this.
  14. 302GMC
    302GMC
    from Idaho
    Not without the weight, at least not as designed to work. ...
  15. StefanS
    StefanS
    from Maryland
    I have an auto choke carb so I use my choke cable to control my heat riser now
