Technical Low compression 276 Hemi Desoto.
Discussion in 'The Hokey Ass Message Board' started by The Rabid Whippet, Feb 18, 2015.
  1. What is the compression at idle on a 7-1 compression 276 Desoto hemi? Does anyone know? My compression is even on all cylinders at 135 . My Vacuum is around 13 idling in neutral. I am not use to this low of vacuum reading but then again, I have never run an 1952 small cube low compression engine either. Thanks in advance.
  2. aaggie
    aaggie
    Since compression is equal in all cylinders I would think the rings are serviceable. Did you run a second compression test after squirting some oil in the cylinders to test the valves? It is important to connect the vacuum gauge into a direct manifold port not just any open place on the carb.
  3. 302GMC
    302GMC
    from Idaho
    At idle ... have you come up with a new type compression test ?
  4. sunbeam
    sunbeam
    Motors manual sez compression 130 psi vacuum seems low check for leaks and late timing the manual sez 4 deg.
  5. 73RR
    73RR
    Stock cam ?? Other details?
  6. ....at idle,,,? if you are checking dynamic compression on each cylinder in turn while running, the vacuum is probably affected by one dead cylinder.
    As mentioned, check timing.
