Technical Low Fuel Pressure Gauge
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Jul 10, 2024.
  1. ‘28 RPU
    ‘28 RPU
    Since I only need 2.5# PSI why do I need a gauge that goes to 15#? I would like to buy a 1-4# or 1-5# gauge. I would prefer a good quality (not chinese) gauge, a used one would be fine.
    Outback likes this.
  2. Bandit Billy
    Bandit Billy
    I wish I could tell you they make a nice looking one but they don't as far as I know.
    This is mine, 0-10 and the 2-3 is in red so easy to see what you are doing. LCE is the name on it.
    If you find something that looks nice don't forget to post a pic of what you get.
    bchctybob likes this.
  3. skooch
    skooch
    Never seen one in those increments. I use a marshall which I think is very attractive and have a matching oil pressure gauge on my firewall.
    RMR&C, Bandit Billy and bchctybob like this.
  4. swifty
    swifty
    Apparently Marshall make the Moon fuel pressure gauges but both gauges go up to 15 p.s.i. The one @Bandit Billy posted looks like a good option, and should be more accurate.
    Bandit Billy likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    Look out side of automotive,
    Pretty much all low pressure gauges that are 0-5 psi face size are 2 inch size .
    & bigger , European, German , Japanese companies
  6. petersyl
    petersyl
    skooch likes this.
  7. wheeltramp brian
    wheeltramp brian
    I've used the Marshall gages with success and they look nice.
  8. 05snopro440
    05snopro440
  9. Automotive Stud
    Automotive Stud
  10. ‘28 RPU
    ‘28 RPU
    I reached out to that member, we’ll see what happens. Once outside automotive gauges there are definitely some 0-5 gauges available. There are also 0-10 psi gauges that are liquid filled. Liquid filled isn’t a must but it would be great if I could find a 0-5 liquid filled. Thank to y’all for the help.
    chlsnk likes this.
  11. ‘28 RPU
    ‘28 RPU
    I noticed that too Studley
  12. 19Eddy30
    19Eddy30
    from VA
    I was told by Marshall ,
    The way the gauge mechanism is design that the housing for the gauge that is roughly a 50 Cent piece diameter would be too big for low pressure sweep 180- 260 deg to fit in the housing for such low pressures, and accuracy,
    This why 0-5 ,0-10 much bigger
    2 inch plus gauge size
    skooch likes this.
  13. Ebbsspeed
    Ebbsspeed
    Check Grainger. They have a bunch of 0-5 psi offerings.
    05snopro440 likes this.
  14. 05snopro440
    05snopro440
    You might be right, it looks like it has the same amount of sweep as the 0-5 psi range on a 0-15 psi gauge.
  15. chlsnk
    chlsnk
    I've had this same issue installing Weber Carburetors on import trucks which like 3 lbs or less of pressure. Finding a fuel regular and gauge can be a bear. I've always ended up using 2" industrial gauges and holley fuel regulators. The low pressure ebay gauges are rarely accurate and usually have a short life.
    19Eddy30 likes this.
  16. ‘28 RPU
    ‘28 RPU
    I’m good with using a larger gauge in order to get what I want. I suppose that in theory, once the regulator has been set then the gauge would no longer be needed but I doubt that the regulator is that precise or consistent. I would still like to find a 0-5# liquid filled gauge which may be out there but I haven’t found it yet.
  17. 19Eddy30
    19Eddy30
    from VA
    Many complaints , & I myself have had issues with the liquid filled,
    ( 0-5 ) & other pressures , after hot & heat transfer pressure on gauge would go up,,,
    ( I would remove liquid from gauge))
    Now I'm thinking I'm will have to do a test on that
    ""Heat transfer gauge reading higher""
    I will get around ,make a Tree , calibrate and note gauge reading Cold , after calibrating 4 or so gauges,
    (accuracy and note )
    Then test One liquid filled and Two non, Non-filled then a
    liquid filled in middle and then a
    non-filled on end of tree , & see If liquid filled one if pressure rises ,,if the two on the outer ends do also,, or hold steady or go up in pressure,,
    I deal with some gas applications that are very pressure sensitive, 1.5 to 2 psi ..
    SS327 and lostone like this.
  18. lostone
    lostone
    from kansas
    @19Eddy30 would absolutely love to see what you find out !
  19. 19Eddy30
    19Eddy30
    from VA
    i will have to get a Liquid filled because all the ones I have are empty,
    Up until about a 6 months ago,
    (gauge about two month old at the time)
    I was running a Marshall
    ( nothing against Marshall)
    I was running a 100 spi gauge,
    It was Liquid but drained, using on High fuel pressure 65psi , on open hooded car,
    Was testing made p*** , next thing I know liquid all over the windshield,
    Strong smell gas , killed engine ,
    Smell gas but could not see anything I flipped the electric fuel pump on and gas started spraying out of the gauge that made me kind of nervous , i'm glad that the air Dynamics of my car routed the fuel upward and over the roof instead of cross the headers
    because I was on a mid 6 sec p*** testing on the street , called my nephew at 2 AM to go to my shop and bring me pipe plugs,,,
    So since then I'm using electric censored fuel pressure gauge, for many years I've ran fuel gauges and I never had one do this (name brands)
    Just Gary and lostone like this.
  20. Speed~On
    Speed~On
    It may be difficult to find a 5psi fuel pressure gauge.
    Here are 2 Stewart Warner 10psi that are older Made In U.S.A.
    2 5/8"
    https://www.ebay.com/itm/3869689210...GcO1OIySry&var=&widget_ver=artemi***edia=COPY
    Here is a smaller 2 1/16"
    https://www.ebay.com/itm/3153637888...GcO1OIySry&var=&widget_ver=artemi***edia=COPY
    I understand you would prefer a smaller numbered gauge, but these are a good next best option.
    Here's a 2 5/8" I had, but sold. I mounted the gauge in a chrome cup and I thought it looked pretty nice.
  21. ‘28 RPU
    ‘28 RPU
    I am resigned to the fact that I will need a larger gauge than ideal and probably use a 10# gauge as well. In general, nothing “new” is worth buying but sometimes there is no other option. I like that vintage SW and would buy one if I find one.
  22. Ducbsa
    Ducbsa
    from Virginia
  23. seb fontana
    seb fontana
    from ct
    Here is a 2 1/16"
    I have a gage as in above pic. Can send actual pics if you pm me a phone number.
  24. bushwacker 57
    bushwacker 57
  25. triumph 1
    triumph 1
    ****s hot rod carbs. He was a member on here & I bought one of his that works great. I had a marshal liquid filled before that & the pressure would always change by at least one psi from hot to cold. I’m told glycerin filled gauges react with heat a mine is mounted on the fuel block on my firewall.
  26. Weedburner 40
    Weedburner 40
    McMaster Carr carries several low pressure gauges. 0-3,0-5, 0-10. They are 2 1/2" dials.
    Illustrious Hector likes this.
  27. pprather
    pprather
  28. Beanscoot
    Beanscoot
    The McMaster Carr gauge (presumably the 0-5 psi similar):
    The ****ster gauge:
  29. 54chevkiwi
    54chevkiwi
    You guys were all expecting something else..? What else did you expect? What's wrong with the sweep? Not a lot of confusion there, the needle in the middle of the numbers is the perfect spot OP wants a gauge to be. Not a lot of mistaking that even at a glance when the direct middle of a fairly flat sweep like that shows exactly the pressure the guy wants to see
    clem likes this.
  30. 05snopro440
    05snopro440
    When the OP is finding 0-15 gauges that are a full sweep, but wants 0-5, clearly he wants a larger sweep and better resolution of the readings. The 0-15 from ****s looks like the same 0-15 just with a reprinted face that only goes from 0-5, so it doesn't give any better resolution.
    Driver50x likes this.
