Technical Low pitch whirling, winding down noise when slowing down/decelerating
Discussion in 'Traditional Hot Rods' started by Spike788, Aug 11, 2023.
  1. SBF 302 and C4 transmission. Well now another issue came up. All of a sudden at speed (30-40 mph) when letting off the gas/decelerating there is a definite low pitch whirling or winding down sort of noise. Not extremely loud but it's definitely there. Hard to tell where exactly it's coming from. For sure wasn't there before today. Not when braking, just letting off the gas and slowing down.
    Something seems off. Don't have the car with me. Left it at a friend's house. It's being towed here Sunday since it's going to rain the next couple days. Having it towed because it was 20 miles from home and didn't want to risk it. Thoughts? Driveshaft? U-joints?
  2. RmK57
    RmK57
    First thing I would is check the fluid levels in the differential and transmission.
    warhorseracing and 427 sleeper like this.
  3. jaracer
    jaracer
    You might try running it up to 40 and shifting into neutral and see if the noise is still there. That disconnects the engine and torque convertor.
    Rex_A_Lott, Just Gary and dirt t like this.
  4. 427 sleeper
    427 sleeper
    Check the wheel/axle bearing's too. Does it do it while accelerating and you just haven't noticed it yet?
  5. bobss396
    bobss396
    Car manuals used to have a rear end gear noise diagnosis chart in them, very handy to have. It would be nice to rule out the rear first off. Get that out of the way.
    Things that come to my mind are a possible bad axle bearing or loose pinion nut. Both easy enough to check.
    partssaloon likes this.
  6. Not sure if it's happening when accelerating as the engine would drown out the noise. As soon as you let off the gas the engine itself naturally is much much quieter which is when you notice the noise as you slow.
  7. Boneyard51
    Boneyard51
    Check your pinion adjustment and/ or bearings.
    Bones
    bobss396 likes this.
  8. Get rid of it. That solved my problem with my whiney ex-wife!
