Low speed tire wooble
Discussion in 'The Hokey Ass Message Board' started by Mr. Weld, Apr 12, 2010.
  1. Mr. Weld
    Mr. Weld
    Just test drove a 31 2dr sedan that I built and am having a problem with a low speed tire wobble.. Axle is back 7 degrees, 1/8 inch toe in, anymore makes it worse, cowl steering, arm runs at the same angle of the front wishbone.. Any suggestions???
  2. Unkl Ian
    Unkl Ian
    1/8" sounds a little high.
  3. striper
    striper
    Hundreds of posts about this on here. Search "Death Wobble" or "Caster Wobble".
    Unfortunately you probably won't find one definitive answer but there are sure a lot of leads to chase up.
    Pete
  4. R Pope
    R Pope
    Borrow some rims and tires, and try it again. Some tires seem to have a twist to them, they just won't work on some front ends.
  5. Mr. Weld
    Mr. Weld
    Got lotsa good ideas off searching those two suggested searches, now back to work on finding it
  6. Mr. Weld
    Mr. Weld
    After reading posts about my problem I looked at the Speedway draglink and could easily flex the link by hand, grabbed a piece of .187 wall 7/8 o.d.tubing from my material rack, cut and threaded each end, replaced the piece from speedway and back in da road she went.. I tried to look for bumps in the road to make her go crazy again and didnt even offer to do the "death wobble" with me.. PROBLEM SOLVED!! Thanks for any help offered up guys, hope this helps anyone else having the same problem
