lowbuck louver press
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Apr 19, 2013.
  1. hotrodderhaag
    hotrodderhaag
    im wanting to order a WILLIAMS LOWBUCK LOUVER PRESS ... what have you all herd about this equipment? for a personal use, i think it looks great, and with having to fabricate the c throat, i can make it to meet my needs. and there cheap also. just looking for opinions
    thanks
  2. young'n'poor
    young'n'poor
    from Anoka. MN
    I got no info for you but ill bump it up in the hopes that need louvers? Replys.
  3. backwoods96
    backwoods96
    from Mead, Wa.
    Good unit, I have been using mine for 4 years now. No problems.
  4. dreracecar
    dreracecar
    from so-cal
    Having owned a louver press and have done 1000's of punches, dont expect to much quality that you could start doing them for others and start charging money.
    Dave is a great guy and realy has made a difference to this hobby with affordable tools, but they tend to favor the do it just for yourself type of hobbyest.
    The drawback to his dies is that there is no holdown bar on the punch itself and once the punch gets a little worn or slop the die wont cut clean and start to rip.Progresivly the spacing gets bigger and now it looks like **** because nothing lines up. My punch had a replacable tool steel blade and a back bar to hold the metal from twisting as the punch came down into a die that had rubber in it to shape the metal.
    Mittler Bros has a better louver die set package.
  5. hotrodderhaag
    hotrodderhaag
  6. dreracecar
    dreracecar
    from so-cal
    Then its perfect, but in doing a hood , you are going to need lots of hands and sombody to pull the handle. Start with a s**** hood first and you will have to strip the paint off both sides to get a clean cut. The pix show flat aluminum which is far different that a steel hood. dont even think about stainless.
  7. hotrodderhaag
    hotrodderhaag
    I will keep that in mind. Thanks alot for the advice... Glad someone with experience chimed in. I've never punched a louver. Operated many press brakes and punches so it should come out ok
  8. dreracecar
    dreracecar
    from so-cal
    But have you ever punched a curve? Totaly different since its moving around. By having a hold down bar on the back of the punch and punching it into a shaped die backed by a rubber insert one is streching the material into shape whereas the LB is just pushing material noticable in the pix by the wrinkles around the louvers. It all depends on what type of finnish you and others are after.
