1952-59 Ford Lower A arm?
Discussion in 'Off Topic Hot Rods & Customs' started by ajracing9, Aug 2, 2023.
  1. ajracing9
    ajracing9
    Hey guys so I've been chipping away at my list and one of the items was to torque down all my suspension components. All was going well until I got to the lower arms specifically the front part. The p***enger side was fine 20230720_184620.jpg
    But I noticed I needed a deep socket for my driver side. Looks like the bushing got ****ed in somehow? Has this happened to anyone else?
    How bad is this? Should I get a new bushing?
    Thanks guys!
  2. bobss396
    bobss396
    Possibly a longer stud there? The bushing looks okay, do you have a loud squeak? Which is usually a sign of a bad bushing.
  3. evintho
    evintho
  4. HOTRODPRIMER
    HOTRODPRIMER
    Almost 70 years old, yeah I would suggest replacing them. HRP
    JeffB2 likes this.
  5. 40cpe
    40cpe
    from Star, MS
    I see in the second picture, looks like the bushing disintegrated and someone took up the slack.
    nosford likes this.
  6. ajracing9
    ajracing9
    Thanks for the response guys! So the car has brand new bushings and has not been on the road yet yet with them. I measured the bolts, they are the same length. So this is the p***enger side the
    And this is the driver side. The a arm is up against the frame.
  7. Dos Cincos
    Dos Cincos
    Something seems off with the front crossmember to me. Did the a arm get pulled into the crossmember when you tightened it up? Did you check to make sure the crossmember was in good shape and not rusted before starting?
  8. 56longroof
    56longroof
    Don't take this the wrong way but, are you sure they were both installed correctly?
  9. ajracing9
    ajracing9
    All the steel underneath was pretty solid, at some point in the car's history there must have been some m***ive oil leak everything was coated in a bunch of Grease. Made for a mess to clean up but all the steel underneath was pretty well preserved. All nuts and bolts came off with out needing heat or breaking.
    I may have installed the bushings incorrectly, everything looked like it lined up just fine. If I remember right there is a little bump on the sleeve that stops the bushing from going too deep. I say the bushings are brand new because they've never been on the road yet but I bought the kit several years ago. I already had to replace the ball joint boots because they were cracked. Cheap rubber I guess.
    I guess I'll just order some new lower bushings they're not that expensive but I just got everything back together and tightened up. It's always 1 step forward 2 steps back lol
    JeffB2 likes this.
  10. fordsbyjay
    fordsbyjay
    from Lafayette
    Those bushings can be pressed to where ever you want. It could have very well just been pressed on a little deeper. When you look at the frame diagram there is a certain distance it's supposed to be but IMO it is designed that way to allow to fit different ch***is. Face it, these frames were made with some pretty low standards and sloppy tolerances, just look at all the booger welds. They are not all straight either.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Best to use these they won't go to pot like the offshore rubber **** will. https://www.energysuspensionparts.com/universal-dust-boots.asp Also like their sway bar links and bushings.
  12. ajracing9
    ajracing9
    Thanks guys! I ordered some lower bushings from rubbertherightway.com I'm sure it's all the same stuff but hopefully it's a better quality than what I had previously.
    I love polyurethane it's so far superior than rubber. I wish there was an energy suspension master kit for our cars. Would make life a while lit easier lol.
  13. 50Poopbox
    50Poopbox
    Anyone have a picture of which way the bushings are supposed to go in to both upper and lower control arms? All the rubber was completely gone from mine and I failed to take a picture when I removed the old bushing sleeves.
