Lowered 62 tempest
Discussion in 'The Hokey Ass Message Board' started by 46poncho, Jan 26, 2010.
  1. 46poncho
    46poncho
    from Indiana
    Does anybody know if it is possible to lower a 62 pontiac tempest with a stock 2 speed auto trans-axle without the back wheels tilting like a volkswagon?? Is there a lowering kit that would work like for a corvair, vette, or maybe even a volks wagon that could be modified to work??? any ideas???
    Thanks!!:confused:
  2. J Man
    J Man
    from Angola, IN
    not 100% but I think the suspension id similar to the Corvair. The only way I know to lower the rear on one if those is spring or bag/hydro setup. The front is closer to the Skylark/F85 if I remember right and your best be would be bagging or spring again. I have been told that a Nova/ChevvyII spindle will swap in the Skylark so I would guess it would work on the tempest as well so you might be able to get a 2" drop there.
  3. RichFox
    RichFox
    It's a swing axle rear. I don't know how to lower it with out a bunch of camber. You might be able to swap in a later Corvair IRS axle. Or raise the entire rear trans axle in the body. Lots of work.
  4. stuart in mn
    stuart in mn
    I don't think you'll be able to lower it more than an inch or so. As mentioned, since it's a swing axle rear there's no way to get rid of the camber without extensive modification.
  5. killer-D
    killer-D
    Here is my wagon lowered
  6. Best way with any trans axle is to move the entire ***embly as a unit. Its not easy but it can be done.
    Ther is another option but I'm sure you don't want to hear it so stick with moving the entire ***embly as a unit.
  7. John_TTD
    John_TTD
    from Michigan
    With the rope driveshaft, swing axles, transaxle it's not an easy prospect, how much are you looking to lower it?
  8. 46poncho
    46poncho
    from Indiana
    I am hoping to drop it a little. I really dont want to raise the trans, ropeshaft, and re-angle the engine to keep the proper geometry! Maybe I can compress the spring a little without changing the camber much???
  9. 46poncho
    46poncho
    from Indiana
    Goodlooking wagon, how did you lower your??? I would upload a pic of mine but keep getting error
  10. 62 tempest nashville
    do you still have the tempest ??
  11. 46poncho
    46poncho
    from Indiana
    yes still have the tempest, blew the motor up today though
  12. gnichols
    gnichols
    from Tampa, FL
    A hunch... soften the rear spring(s) and somehow extend the upper suspension links to tilt the wheels outward and get the camber back to OEM specs? This being said by a guy who only drove a 63 for awhile, I have no idea what the Tempest IRS looks like in the flesh. Gary
  13. RichFox
    RichFox
    As I remember my Temptest was swing axle. Not IRS. See my post # 3 above. As such, no "upper link" to get the wheel back straight.
  14. BrandonK
    BrandonK
    Not to bring this back from the dead, but does any one know if the 61-62 tempest shares the corvair suspension? I am looking to put my 62 on air ride come spring and have heard they share the suspension, but I have not been able to confirm. If they do I can buy a kit rather than try to make something custom. Thanks in advance.
