Technical Lowering 35 Ford and retaining mechanical brakes?
Discussion in 'Traditional Hot Rods' started by fftoddster, Nov 26, 2017.
  1. fftoddster
    fftoddster
    Is it possible to retain the mechanical brakes on a 35 Ford and lower both front and rear?
    Dropped axle up front, rearced spring and shackles in rear.
    What problems can I expect?
    What needs to be done?
    Thx
  2. BJR
    BJR
    I have to ask.... Why?
    studebaker46 and scrap metal 48 like this.
  3. 55styleliner
    55styleliner
    Why do you want to keep the mechanical brakes? 39-46 juice brakes bolt on. Mechanical brakes are all about leverage to have them work right. You can’t have bends in the rods. And any angle between the rods and the ground could change the leverage and make them less effective
  4. seb fontana
    seb fontana
    from ct
    I would think that the mech brakes will work just as well as a 4" drop is well with in the stock suspension travel range..If you use longer shackles in the rear you should put a panhard bar on to keep sway at bay.. ...
  5. uncle buck
    uncle buck
    Reverse eye springs are probably your best option. The mechanical brakes in the front are integrated into the king pins . A dropped axle would be a challenge to relocate the brake cross shafts up front and not compromise the geometry and safety
  6. I've had our 36 Ford over 30 years or so. Still has mechanical brakes. Screwed with them many times and still they are pretty lame. Car is stock height. If I do anything to the suspension, I'd do juice brakes first.......
    Ya got pics of your car??
  7. fftoddster
    fftoddster
    Thanks. I used the MP Bendix type brakes on my 37, just checking options and ideas if I land another car...
  8. RussTee
    RussTee
    There are several threads on doing this with a model A the process would be similar
