lowering 36
Discussion in 'The Hokey Ass Message Board' started by 36coupe, Jun 6, 2008.
  1. 36coupe
    36coupe
    from Oklahoma
    hi, i want to lower rear of my 36 coupe a little, anyone know how much the drop would be removing the two small leaves,including the leaf thickness thanks.
  2. weemark
    weemark
    from scotland
    vic the leaves themselves will give you about 3/8", as for lowering when removing leaves, depends which leaves you lower as to how much support you loose.
    would be better to fit a posies low reverse eye spring, or buy a main leaf only with reverse eyes, kerry tate can get them made up for you, reverse eyes will give you a drop of about 1.5"
  3. Fogger
    Fogger
    When I was 13 I lowered my '35 Ford with 6" shackles, I am luck not to have killed myself. As Weemark stated a Posie low reverse eye spring is the way to go. At least to get 1 1/2" to 2" lower. Good luck, The FOGGER
  4. Anyone got some pics of these springs installed, what about lowering the front?
  5. Dooley
    Dooley
    from Buffalo NY
    I lowered the front of mine with a reversed eye spring from Posies.
    Stock 38 Ford axle.
    It's not super low, but the rear is kinda high so it works.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    This is a reverse eye spring (adjustable by adding different center blocks) on the rear installed last summer.
  7. DrJ
    DrJ
    Longer shackles will work without the death-sway if you at the same time add a panhard bar to control it.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    Exactly what Ford did in 1942 when they stopped mounting the springs under tension as they has since 1909.
  9. 36couper
    36couper
    from ontario
    I installed the Posie's super slide on my coupe. It's pretty simple. And if I can say that, it really is pretty simple. I had a club mate do the welding. Pic......
  10. Preacher
    Preacher
    Second that on the posies... my buddy put one in his and it was really smooth installation
