I was going to block the rear to lower it some, but I'm not sure where to find longer versions of the flat-bottomed u-bolts that hold the stock axle to the leaf spring - any ideas? Doen't sound like something I ought to make out of all-thread....
most of the "off the shelf" square U bolts for our cars are for "1-"2 blocks. I had some longer ones made at a muffler shop for my '54 . " National Chevy " http://www.nationalchevyassoc.com/ has the shorter ones. also, http://www.hotrodsofnorco.com/
The guys that do alot of off the road stuff have them on there 4/wheel drive trucks, they just go the other direction! I picked up a used set at a swap meet last weekend, 10 bucks, 3" block, extra long U bolts.
I've used BRS kit, it can be had with or without blocks, plus it centers the axle,if you are using stock springs....
I took an origonal one down to my local spring company and had them make me some 4 in longer for about 15 bucks.
Do you run stock size tires? I want to 4" in the back of my 51 chevy but wasn't sure if i'd get tire rub or hit anything going that low. Thanks
You should have plenty of room I was running 235/75/15 and diddn't rub on ant thing...but my rear axle ( 9in ) on deep pot holes would come up and smack the frame. Krupanut has 4inchers and dosent have a problem with his tires either.
No problem with the tires but I do smack the frame on sometimes. Regularly with people in the back seat.
