lowering a 50 poncho
Discussion in 'The Hokey Ass Message Board' started by THE CHIEF, Oct 15, 2007.
  1. THE CHIEF
    THE CHIEF
    from MIAMI
  2. Verbal Kint
    Verbal Kint
    from Washington
    I cut a little over 1 coil out of my 52 pontiac 2dr post in order to match the 3"+ blocks in the back. I didn't drive the car very far before I sold it to another HAMBer "Donohue". In that short distance I didn't think it rode bad at all (over driveways, down alleys, thru potholes). However, I had planned on t******* the snubs in half and getting some firmer shocks to compensate for it bottoming out. I will cut the same out of the coils this next time and make similar blocks for my 52 hardtop.
    s.
  3. Orn
    Orn
    This is my buddy’s –49 Poncho and he have 3” block in rear and cut 1 1/2turns on the front coils. The ride is excellent with no bottoming out what so ever.
  4. atomickustom
    atomickustom
    You can also put a spacer between the lower A-arm and the spring pocket (lots of drilling out rivets, but otherwise a straightforward job). A 1-inch spacer will give you about a 3 inch drop. You keep your springs and shocks at their normal length, with gives a less stiff ride than cutting the springs. You might bottom out a little easier, though. Ride quality is very subjective, but I would say the car I did this on rode better than stock UNTIL I hit a sharp bump, at which it would bottom out pretty hard.
