Projects Lowering a 53 ford customline 4door
Discussion in 'The Hokey Ass Message Board' started by Barberjim, Mar 19, 2015.
  1. Barberjim
    Barberjim
    I just bought a 53 ford customline and would love to lower it. But not sure the proper way of going about it.
  2. Road Angels
    Road Angels
    Depends on how low you want to go and what your willing to spend
  3. Barberjim
    Barberjim
    Low but drive able and I not looking to spend more then a grand
  4. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I had a 53 Vicky back when I was in high school and lowered it by turning the spindle supports up side down. You invert them and then also reverse the sides, right one on the left etc. Then you generally have to heat the supports and bend them into alignment. Another way if you don't want as much drop is to add a spacer between the lower A arm and the plate that the spring rest on. You will need to knock out the rivets and then replace with grade 8 bolts. And of course you can cut the coils. I attached a pic of my 53.
    Rex
  5. Barberjim
    Barberjim
    That looks clean
  6. Squablow
    Squablow
    3" blocks in the back and Aerostar van replacement coils in the front, along with some replacement shorter shocks. A couple hours, about $120 depending on where you get your parts from, it'll ride great and look real nice too. There's a few threads already about the Aerostar coil swap, seach some out, should be part numbers available. My '52 has that setup and I love it.
  7. missysdad1
    missysdad1
    ^^^^ Yeah, what he said.
  8. Vegas_Cleaver
    Vegas_Cleaver
    I second the aero springs and 3" blocks that what I did on my 55 ford
  9. Barberjim
    Barberjim
    What year Aerostar coils do I use and am I going to need to cut them?
  10. paleot
    paleot
    from louisiana
    I ordered 93 aerostar springs for mine initial drop was 2½" settled at 3".
  11. Barberjim
    Barberjim
    Awesome thank you.
  12. BLUDICE
    BLUDICE
    Right now I've just got 2" blocks in the rear of my '52 (pictured) - nothing up front yet.
  13. Barberjim
    Barberjim
    That's a nice stance on it.
