Lowering a 54 ford
Discussion in 'The Hokey Ass Message Board' started by Baggs, Jan 7, 2010.
  1. Baggs
    Baggs
    Whats the best way to lower the front end of a 54 ford car?? i lowered a 55 with the lowering blocks for the a-arms, came out real nice, drove real nice. but was lacking the drop i was looking for. was hoping for an inch or more. does any company make dropped spindles for that car? or are there spindles of off another car that would work?
    Baggs
  2. Do a seach on Aerostar springs. You will find a lot of info on lowering your 54 about 3 to 3.5 inches using Ford Aerostar front spings. Did mine this fall - rides nice. The post also has part numbers for new shocks to use with the shorter springs.
  3. Tank
    Tank
    Fatman makes 3" dropped spindles. Gotta use Granada brakes though.
  4. Baggs
    Baggs
    i checked the fatman site, must not list it on there. how tough is it to find granada brakes? so im ***uming you have to convert to disc brakes? which i would want to anyway.
  5. xtralow
    xtralow
  6. desertdroog
    desertdroog
    I used a combo of dropnstop.com's spindle kit and the Aerostar Moog Spring swap. Total of 5.75 inches drop over stock on my car doing nothing else.
    3 inch blocks in the rear with saggy springs, s****es when I leave my house, but that is due to the 50's curb out there and you will have to take most driveways at an angle and speed bumps slow.
    To go lower requires bags or hydraulics.
  7. Baggs
    Baggs
    well, i will have to see where it sits when put together, but i want it low. so probably need a combo of spindles and springs.
  8. bryan6902
    bryan6902
    Talk to Kremer spring in Inver Grove Heights, they can make any spring you want. I had them make 3" drop springs for the Pontiac. Still may be cheaper to do spindles and Aerostar springs but may be worth checking into.
  9. Baggs
    Baggs
    there are a few options out there, just want a good ride ya know
  10. oddrod46
    oddrod46
    from Georgia
    I know this is an old thread but out of curiosity. Did you ever change the shocks out? Or just the springs?
    Kustomline54 likes this.
  11. pprather
    pprather
    Sorry, @Baggs has not been here since 2016.
    I sense from the conversation that the shorter aerospace springs require changing to shorter shocks also.
    Kustomline54 and oddrod46 like this.
