Lowering a '55 buick.. need some insight..
Discussion in 'The Hokey Ass Message Board' started by bhead1968, Jun 2, 2012.
  1. bhead1968
    bhead1968
    from so-fla
    I finally got my first vintage vehicle, i was looking at lowering it a bit and may go the mild custom route. I have explored bagging it, but having something lowered the "old" way seems a bit more appealing to me. My '55 buick is bone stock and I would like to find out what options i would have to lower it. With that said, how many inches would be "Safe"? I plan on riding the piss out of it and want to insure i wont have to be driving sideways over speed bumps at 2mph.
    Thanks in advance..
    bh
  2. Butch11443
    Butch11443
    I believe the Buick is coils front & rear. Can heat, or cut them. Also, can order custom springs to lower it. I defnitely would not lower it past the scrub line.
    Butch
  3. bhead1968
    bhead1968
    from so-fla
    Yup, should have mentioned that. I've seen the Heating method, but doesnt that compromise the actual steel in the spring and make it more "loose"... i think there was a term or something on how it effects the performance of the spring. Cutting seems a cheap and easy way, but how much?..
    thanks again.
  4. DualQuad55
    DualQuad55
    from NH
    Cant cut the rear springs as they are pigtailed on the ends-meaning the coils wrap tighter on the ends where they mount. You can heat/collapse them, use clamps to collapse them, or just order lower springs.
    Ordering lower springs usually results in the best situation as theyold springs are usually shot anyhow.
    Lowering the front has some slight issues with alignment if lowered excessively, causing tire wear etc...
    Rear springs are easy to swap out, fronts take a little more effort.
  5. domepiece
    domepiece
    remove the coils and cut a 1/4 coil at a time. With a grinder and a cutoff wheel. Do all of them at the same time. Put them back in and go drive it around. If not happy with how low it is then just repeat the process. It will take awhile if you have to do it a couple times but it's definately cheaper and faster then cutting to much and haveing to locate and buy new springs. You may have to get shorter shocks once its all said and done.
    heating springs will weaken them where they were heated and they will eventually break. It changes the spring rate of the spring itself.
    good luck.
  6. 40FordGuy
    40FordGuy
    My vote is for new springs....those originals have been in there since "Day One"... They deserve a retirement.....
    4TTRUK
  7. 41super
    41super
    Used Fatmans dropped spindles on the front and new springs 2" shorter on the back to lower my 55 Buick Special.
  8. enjenjo
    enjenjo
    from swanton oh
    78 Malibu rear springs bolt in, and drop the back about 3 inches
    BensonStripes! likes this.
  9. BensonStripes!
    BensonStripes!
    Anyone know if the front springs on the '55 are the same as '53? "OEM" springs from places like Kanter are ridiculous. (Sorry for the brief hi-jack.)
  10. Roadsterpu
    Roadsterpu
    I suggest using Jamco Springs. They are made for the car and you can order them in 1"-3" shorter versions.
    Here is my 56 with 3" lowered springs
  11. O'Doyle
    O'Doyle
    I second the Jamco springs method. Put 3" drops in my 55 and I'm really happy with the new ride height. Springs and shocks took a while to get to me but well worth the wait.
    This is the only shots I've got so far but will take some side on shots this weekend.
    O'Doyle
  12. hustler1984
    hustler1984
    from lindsay ca
    I cut my coils in the beginning and it looked awesome but rides like ****, I would recommend fatman spindles and scarebird disk brake upgrade if you had the 700 to spend. I ended up bagging mine in the end
  13. Chris Stapley
    Chris Stapley
    I built a 56 Convertible and used stock 305 springs from a 1978 Olds Cutl***, no chopping, rode great and dropped 3 inches as well...
  14. kosnmotion
    kosnmotion
    from Phoenix
    Did you have to modify anything else? Do you still have room and not have to cut the front bump stops? Thanks. looking to put these in mt 55 this weekend
  15. TP
    TP
    from conroe tx
    I have a 59 buick and took the rear springs out and visited the wrecking yard. They had a rack full of springs off of various cars. I found some the height I wanted and pigtail configuration that I needed. Cost $20.00. Rides great.Dropped it about 6-7" in the rear. I dropped the spring pockets in front. I made spacers out of 1" square tubing.
