Projects Lowering a front axle
Discussion in 'The Hokey Ass Message Board' started by JReece, Dec 20, 2025.
  1. ALLDONE
    ALLDONE
    I think pete and jakes, and speedway have all this info on their sites..
    mad mikey and Okie Pete like this.
  2. proartguy
    proartguy
    from Sparks, NV
    In addition, that long drag link combined with the difference in angle with the radius arm will probably make for some interesting bump steer.
    mad mikey and ALLDONE like this.
  3. ALLDONE
    ALLDONE
    LOL.. so here's what I would do for you if you if you brought this to my shop,,,I would make a block just like you ask'd and put it on top of the mount you have, drill four holes in it , and make it long enough to to go on the cross member... I would take 1/2'' stock, use my plasma table to cut a block to fit with holes for the u bolts I would weld the block in and mount the spring on top of the mount like you ask'd and be done... it will work with the spring you have...and the shackle's... they will work as is.. but not 100% correct... but will work... to fine tune it you could get the correct spring and shackles...
    this is my RPU front... it's perfect. spring on top. rides and drives perfect,...LOL been down the freeway 1000's of miles through the years..
    duecesteve, Okie Pete and TERPU like this.
  4. ALLDONE
    ALLDONE
    oh.... it also has friction shocks that work perfect...
  5. ALLDONE
    ALLDONE
    note the smile on the springs and angle of the shackles.... perfect.....lol
  6. ALLDONE
    ALLDONE
    correct...
  7. Yep.
    wrong spring
    Start by getting a correct one
    Then go from there
    mad mikey, Okie Pete and High test 63 like this.
  8. I’d recommend getting one of these
    amd a Pete and Jake’s catalog
  9. Too much science and not enough action, just do it ! It'll be fine.
    ALLDONE and JReece like this.
  10. Royalshifter
    Royalshifter
    Moderator
    Run shocks, bump steer and wheel hop can be hard to get out of at a higher speed.
  11. And take care of this too
    looks like a regular nut
    mad mikey, ottersea and JReece like this.
  12. GuyW
    GuyW
    That spring will permanently bend (distort) or break with that reverse curvature at the perch.
    clem, ottersea and JReece like this.
  13. JReece
    JReece
    it has two leafs on it now and no reverse curvature, that was just a pic with one leaf as a reference.
    Outback, ALLDONE and GuyW like this.
  14. alchemy
    alchemy
    I give up. Good luck.
  15. chickenridgerods
    chickenridgerods
    from DSM, IA
    It's going to have barely any spring rate with only two leaves. Standing on it in your garage is nothing like driving down the road. You'll be putting that axle into the crossmember.
    If OEMs could get away with using just two leaves, they would. Monoleaf springs are designed and constructed differently than the main leaf of a multi-leaf spring.
  16. wuga
    wuga
    I agree with alchemy!
    ottersea likes this.
  17. ALLDONE
    ALLDONE
    Did you get er done??
    JReece likes this.
  18. TERPU
    TERPU
    New to this thread, but the combination of parts you have is fighting itself. The Spring is incorrect for the axle set up.
    You will have a very short lived, spongy, and sketchy ride with trying to use just two springs. Especially an aftermarket of unsure make. One Spring is a major invitation to disaster unless it's designed for it.
    Your T should be able to sit damn near on the perch with the right combination. Without it being on top. If you want it on top, that's different. But it'll work correct and be really low right where it's at. It's spring bound and before long the bushings will be worn out. That set up currently is trying to stretch the spring, not let it go through its arch. Like a tensioner at full tension. The spring is designed to get longer by a bit as it goes through the arch. Yours is already as long as it's ever going to get.
    That is why it looks like wings with only one or two in there. Dangerous as the weakest point in the very middle that already has a hole in it is the bending/flexing point. You need more springs in a taper to spread the weight and even the load. That's why springs are tapered in leaf length. It allows each to do its job while being supported. they work in unison not individually. Even a Mono Leaf is a gentle taper middle to each end. But that's a whole different topic.
    In short you need a longer spring, or the right axle/perch distance for those.
    I put a couple of pictures on this. They show that in a stock cross member you can get the car as low as you want. The '34 Pickup has 7 leaves in it on a reversed eye and the T has 6 leaves on a reversed eye. So with the Suicide Perch you should be able to get it even lower if desired. FWIW I had to put leaves back into the '34 as it was rubbing the braces.
    Your T is cool! Just a little bit of work and it'll be fun to drive.
    All the best,
    Tim
    redo32, JReece and twenty8 like this.
  19. Royalshifter
    Royalshifter
    Moderator
    Lengthened home made shackles to try and make the wrong spring fit there is no 45 degree in the shackles for movement.
    mad mikey and JReece like this.
  20. JReece
    JReece
    I agree, and so, I did.
    Here is the latest video:
    Lowering the Front - '23 T Bucket - "Toxici-T!"
  21. twenty8
    twenty8
    I don't think that softening your front spring so much is the right way to get the shackles sitting at 45*. Two leaves is probably not enough. The spring looks too soft. You might get front end bounce and too much roll when cornering. Be real careful on the test drive. It could handle like ****.
  22. panhead_pete
    panhead_pete
    Before doing it check your scrub line at any ride height changes.
    mad mikey, JReece and GuyW like this.
  23. :cool:!!
    JReece likes this.
  24. 282doorUK
    282doorUK
    Maybe air up the tires a tad before you finally decide on rake.
    JReece likes this.
  25. JReece
    JReece
    finally someone noticed.
    282doorUK likes this.
  26. JReece
    JReece
    So, what we are really doing with the front end.
    From measurements it looks to be a Model A spring on a 37-41 axle. So I’ve ordered the correct shackles and that spring should fit perfectly on my dropped Model A axle.
    Current measurements:
    - Leaf spring eye to eye 32.75” (should be a 31.25” that’s currently stretched)
    - Shackle length 3.125” on the car, way too long
    - Perch bosses on the car are 39” minus 5” would be need a 34” spring.
    So, with the Model A axle:
    - 31.25” spring
    - New 1.5” shackles
    - Perch bosses are 36.25” minus 5” is 31.25” spring.
    $40 shackles is much better than buying a whole new spring, and I can add leaves back and still be lower from the drop axle.
    Outback and RodStRace like this.
  27. RodStRace
    RodStRace
    JReece likes this.
  28. JReece
    JReece
    Coming together!
    New shackles and Model A drop axle are on.
    warbird1, RICH B, Deutscher and 2 others like this.
  29. Looks more betterer
    mad mikey, Outback and JReece like this.
  30. alchemy
    alchemy
    Just like was suggested in post #5.
    RICH B, Outback and BigJoeArt like this.
