LOWERING a stock 41 ford chassis
Discussion in 'The Hokey Ass Message Board' started by onegalonly, Mar 31, 2013.
  1. onegalonly
    onegalonly
    i'm looking at this 41 ford coupe for sale.. it is all stock ch***is except for the front disc brake upgrade.. it is lowered by using longer shackles on all four corners.. i don't know how long they are but i'm guessing at least 6 to 7".. has anyone done this before? would the handling be effected in any way?
  2. onegalonly
    onegalonly
    here's a pic of the front
  3. chaddilac
    chaddilac
    That just don't look safe to me!!
  4. onegalonly
    onegalonly
    here's a pic of the rear
  5. need louvers ?
    need louvers ?
    Bad idea! I believe '41 was the last before panhard rods were standard on Fords. The early Ford cross leaf suspension requires that the shackles be at a 45 degree angle to mantain their "built in" panhard effect. If you go beyond that, say the close to 90 degrees in the picture, the frame and body swing back and forth on those long shackles. Take them off and throw them as far as you can!
  6. onegalonly
    onegalonly
    i already told the fellow i wasn't interested, but for conversation, would they work on just the rear if a panhard bar was added
  7. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Looks like a very poor method, why not just take out some leafs if you want to do a cheap lowering job?
    I guess some people just overthink things and feel the need to "build ****"
  8. Straightpipes
    Straightpipes
    Wow, if he botched that up like that I would wonder what other suprises the car has.........
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Without a panhard bar that thing would go down the road like a hula dancer !! But guess what thats the way we did it in the 50s-60s . Pre Ford's installing a factory panhard bar they were known for swaying their hips ! LOL
  10. Well there's only two ways to lower a car :
    1 get the frame mount for the spring ****ed up above its current location and further away from the ground
    2 get the axle mount for the spring closer to the ground
    There's a bazillion ways to get to #1 or #2 some are good some are like these pics.
    Great for mock up to check looks and clearance before the real work starts
  11. longer shakles on the rear will work with a panhard.my 36 ford had this done in the 50s.rides good.
  12. Carter
    Carter
    Holy ****, and here I was worried about using 1" longer than stock shackles with a slightly shorter main leaf that should maintain proper preload.
    Sent from my DROID device using the TJJ mobile app
  13. hotrodderhaag
    hotrodderhaag
    I second that... Those are death traps.. Those will magnify any type of road conditions causing death wobble and steering play. Yikes!
