Lowering Blocks or Air shocks
Discussion in 'The Hokey Ass Message Board' started by Tomcat tweaker, Jun 26, 2013.
  1. Tomcat tweaker
    Tomcat tweaker
    from NORTHEAST
    New to the forum, and was wondering what you guy's and gal's would recommend for my 59 edsel; 3" lowering blocks or Air shocks for the rear? Thanx
  2. need louvers ?
    need louvers ?
    What is it that you are wanting to accomplish? Lowering blocks will lower the back of your car, installing air shocks and filling them will raise it.
  3. Dreddybear
    Dreddybear
    3" blocks would probably be just fine. Watch your driveshaft clearance.
  4. 49ratfink
    49ratfink
    blocks on one side and an air shock on the other.
  5. KJSR
    KJSR
    from Utah
    Placement depends on the size of the p***enger....
  6. Mike VV
    Mike VV
    from SoCal
    Common...he's a new guy..!
    But yea, as noted...lowering blocks will lower...air shocks will raise the car.
    Which way do you want the car to go...up or down ?
    Mike
  7. Really depends what you want. I put 4" lowering blocks AND air shocks in mine.
  8. I'm gonna put both on mine. Lowering blocks so it will be down where I want it, and air shocks to raise it when I go in driveways and over speed bumps.
  9. I got both in mine. You do realize air shocks are not like bags and won't really lower the car just raise it up right?
  10. Tomcat tweaker
    Tomcat tweaker
    from NORTHEAST
    Awe thanks guy's, I am just shy of a smooth brain window licker, but I'm pretty sure I'm looking to lower it. I figure the blocks to lower and the shocks to adjust? Just don't want to go over kill.
  11. HOTRODPRIMER
    HOTRODPRIMER
    That will work,,up or down. HRP
  12. GassersGarage
    GassersGarage
    Awwwwww, give the guy a break. With a name like Tomcat tweaker, maybe he was tweaking.
  13. plodge55aqua
    plodge55aqua
    from Alberta
    especially a Dodge Product .. they always lean to one side...
    :D
    I know mine has that issue..
  14. need louvers ?
    need louvers ?
    Just do the blocks. I wouldn't put air shocks on a pull wagon.
  15. blown240
    blown240
    from So-cal
    Start with the blocks. If you find you need it a bit higher for bumps etc, then put some ar shocks on it. HAVE FUN!
  16. Air shocks aren't meant to carry the weight of a car, the springs are. I have seen many shock mounts blow out after time using air shocks. Maybe bags would be better as they fit where the springs did and thats where you want to carry the load. Alot more reinforcement is at the spring locations.
  17. 2racer
    2racer
    concrete blocks in the trunk will lower it and you can adjust by adding or removing blocks, no mechanical skills needed
