lowering blocks...
Discussion in 'The Hokey Ass Message Board' started by cwatson1953, Feb 23, 2007.
  1. cwatson1953
    cwatson1953
    anyone have any suggestions/preferences on where to get 3" lowering blocks/kits (u-bolts and what not)?
    its for my '53 chevy sedan.
  2. I bought a kit at the local Autozone just for the u-bolts. It only had 1" blocks, but the box said the blocks weren't included! Go figure. If they don't have a 3" kit, get the 1", the u-bolts are looong, and I have many s****s of 2x3 tubing you are welcome to some if you want them. All you would need to do is but a bolt in the rectangle tubing to locate it between the spring and axle.
  3. skyrodder
    skyrodder
    where in houston re you located? what color is your car?
    Buy them at autozone... :cool:
  4. If you've got stock leaf-springs, you'll need the skinnier blocks that places like Night Prowlers sell.
    Bryan
  5. See what I mean?
  6. cwatson1953
    cwatson1953
    yea, i've got the stock leafs on there for now...i just searched through their site and didn't see anything about blocks though...i may be blind though...
  7. cwatson1953
    cwatson1953
    i'm on the northwest side....290 area.
    my car is black body white top. the only way you would have seen it would be pictures...its never been on the road since i've had it.
    you're running your stock rear/torque tube/springs right?
  8. cwatson1953
    cwatson1953
    cool thanks man!
    i may hit you up for some tubing! thanks.
    Chris
  9. skyrodder
    skyrodder
    yeah pretty much everything on my car is stock for now... how much do you wanna lower your car?
  10. Damn...that was driving me nuts 'cause I know I ordered mine there, but it was a couple years ago and I couldn't find 'em either. I checked all the pages and it turns out they put 'em on the "Skirts" page under inventory. Weird...
    I like the idea of making 'em too....cheaper and probably faster.
    Bryan
  11. cwatson1953
    cwatson1953
    thanks alot man!
  12. skyrodder
    skyrodder
    I am looking at a set from national chevy parts and they are 110 bux.. too much for me..
  13. cwatson1953
    cwatson1953
    as much as i can! :D hehe...at least 4 to 5 inches for the moment.
    don't have the funds for bags right now...but was planning a gambino notch, some dearched/remove leafs, and some blocks.
    yea, you've got your ride pretty low don't ya?
  14. G V Gordon
    G V Gordon
    from Enid OK
    This is what we use in Oklahoma, about five in the trunk gets ya three inches. Can usually be picked up at any construction site after 6:00 p.m..lol
  15. cwatson1953
    cwatson1953
    yea, i saw those...i'd rather get some tubing and do it myself.
    and if i remember right their blocks are only like 1 3/4"..??
  16. cwatson1953
    cwatson1953
    haha...yea, i've had some old school guys tell me they used bags of concrete in the trunk back in the day.....hehe...a little TOO primitive for me.
  17. I also have some 1 3/4" square tubing, we could weld two together and get 3 1/2" blocks, probably be stronger than the aluminum blocks I used to crack a hundred years ago when I had a mini truck.
  18. $110! I only want $100.:D Or a 12 pack of Natural Light.
  19. cwatson1953
    cwatson1953
    thats definatley a thought.
    i'm gonna hit autozone this weekend for a u-bolt kit.
    and i'm wondering how low is TOO low with blocks...i've always been told 3" is max. i wonder how bad 4" would be.....
    but yea, i may hit you up sometime here soon for that!
  20. custom61
    custom61
    i just bought some 3" blocks at PepBoys last weekend i paid 32 bucks and it came with u bolts, blocks, and everything
  21. cwatson1953
    cwatson1953
    how about some lonestar? i don't think i can bring myself to buy natual light...even if i'm not drinking it! ;)
  22. skyrodder
    skyrodder
    yup gambino notch, 2 and 3 inch lowering blocks, and remove 2 leafsprings.. oh yeah and raise your driveshaft tunnel about 2 inches, and you will be cruisin low and smooth
  23. cwatson1953
    cwatson1953
    with that much of a "block-drop" you've still got a decent ride?
    i mean, i'm not looking for it to be riding liek a caddy or nothing...i've just always been under the impression of anything beyond 3" block was "TOO" much.
    i've seen the vids of your car driving around and it looks like its pretty smooth...and espeically out on those roads out in the hieghts...i know they ain't always purdy!
  24. skyrodder
    skyrodder
    yeah runs pretty smooth, like you said not like a caddy but it's a comfortable ride for a 50 plus year old dropped car
  25. scootermcrad
    scootermcrad
    for my 54 Poncho (pretty similar to your chevy I think) I bought 4" blocks, u-bolts and angle shims from Speedway. My stock springs were pretty narrow which meant the lower plates had a narrow u-bolt pattern. The blocks ended up being too wide and the u-bolts wouldn't line up with the holes. So.... I bought the universal lower plates from speedway also. Should go together all good now.
    Don't forget about the pinion angle!
    A better way to have done this would have been to get de-arched springs with shorter blocks (or no blocks) or bag-it. Will do that eventually.
  26. Busted Knuckles
    Busted Knuckles
    4 inches might get you well past the scrub line. Never have thebolts too much lower than the rim, taller tires will be better . beee carfull, nothing like hitting a big bump and possibly ripping out the rearend as the shackles dig into the pavement
  27. 53sled
    53sled
    from KCMO
    not a problem with the stock rear! :)
    I have posies and a 2" block on the driver side, 3" on the p***.
    I finally got it to sit level. :eek:
  28. I roll Lonestar, it IS the National Beer of Texas, after all!
    As far as to much blocks, your rear axle tubes are probably 3", half of which would be 1 1/2" ,maybe 1" or less for the spring pad, 3 1/2" block, that's a total of 5" from the center of a 15" wheel, leaving 2 1/2" for your spring pack before going below the rim. If my math is correct, you should be O.K. De-arched springs when you get the $$$$ will be nice, and as long as you trim the bump stops and/or anything else that might be in the way (C-notch the frame? I have some pipe, too.) you will have a decent ride. Get out a tape measure!
  29. Rumplestiltskin
    Rumplestiltskin
    from OK
    Personally, I will never buy the Taiwan kit from Autozone B/C they are cheap pieces of **** that can't be tightened without pulling threads! I have been through 2 sets of their U-bolts and they are ****! They give ya' new ones for free (warranty) but it never changes the fact that they ****!!! All of em'! F em'
    Sorry
  30. Good to know, I will buy some good ones from a fastener supply when the time comes to actually drive my heap.
