Lowering Blocks
Discussion in 'The Hokey Ass Message Board' started by DFM, Apr 9, 2008.
  1. DFM
    DFM
    from Red Deer
    Can anyone tell me wich way to put in the angled blocks, big side to the front or back??
  2. hmm regulary they are flat , it depends your ****** ,rearend angle, both should be the same
  3. bumpybigblok
    bumpybigblok
    from Midwest
    I think you got your hands on some 4x4 lift blocks.
  4. blkcat77
    blkcat77
    Big end almost always goes toward the rear. This should correct a bad pinion angle (you want the front of the rear to be angled down a little). I'm actually going to taper the blocks on my s-10 to correct a bad angle.
  5. lostn51
    lostn51
    from Tennessee
    how much drop are they?
  6. 53sled
    53sled
    from KCMO
    4x4 angle up (taller in front)
    lowrider angle down or flat. pinion needs to be opposite of trans angle.
  7. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Ive never messed with em, only flat, but yeah supposed to correct a certain amount of pinion angle problem.
  8. DFM
    DFM
    from Red Deer
    thanks guys i got er figured, i used 4 inch 4x4 blocks and put the big side to the back and it seemed to work.
  9. punkabilly1306
    punkabilly1306
    from ohio
    any pics on how shes sitting now? and is that the car in question as your avatar?
  10. DKING
    DKING
    from LAS VEGAS
    Lets see some before and after.
  11. oilslinger53
    oilslinger53
    from covina CA
    be careful, 4 " blocks will probably put your u-bolts below rim height....scrubline, very important
