Lowering blocks
Discussion in 'The Hokey Ass Message Board' started by lincolnlog, Mar 10, 2010.
  1. lincolnlog
    lincolnlog
    from Arizona
    I have done a search, but didn't come up with an answer. I have Cast Iron blocks on my 51 lincoln, but the cast blocks are wider along the casting line, causing my u-bolts to splay out like in the picture below.
    Is this ok, or should I grind channels in the blocks to keep the U-bolts paralell.
    Also, the spring pack bolt head is much smaller than the hole in the block, creating a loose fit. Should I be concerned?
  2. LastMinuteMark
    LastMinuteMark
    from So. Cal.
  3. lincolnlog
    lincolnlog
    from Arizona
    sorry, that is not my picture, but is similar to my situation. i am running cast iron blocks on a 51 lincoln. the mating surface of the blocks is the right width for the spring/axle perch, but in the middle it gets wider?? Im going to pull them out and see if there is enough material to clearance them.
