lowering blocks
Discussion in 'The Hokey Ass Message Board' started by 59bug, Apr 13, 2010.
  1. 59bug
    59bug
    from missouri
    I just got my 2 and a half inch lowering blocks in the mail from speedway and the block sitting on the leaf spring is about a qaurter inch on each side can I use the? or maybe I could cut and reweld them. What do you guys think. It's a 50 chevy.
  2. 59bug
    59bug
    from missouri
  3. the block sitting on the leaf spring is about a qaurter inch on each side
    Quater inch what?
  4. I don't think 2 1/2" is low enough.
  5. How about posting some pictures so we know what you're talking about.
    the block sitting on the leaf spring is about a qaurter inch on each side ....don't understand.
  6. Fordguy321
    Fordguy321
    from Arizona
    yeh a visual would be great. well as longs as the u bolts fit
  7. jcmarz
    jcmarz
    from Chino, Ca
    The blocks you have are for newer cars and trucks. Older Chevys like yours uses narrower blocks. I bought a pair of orginal lowering blocks for my 51 off ebay and they are cast iron. I have seen many people use new lowering blocks and it's just mickey mouse. My friend just bought a 38 Chevy Master Deluxe and it had the new blocks. Man, those u-bolts were bent like crazy. The first thing he did was remove them and installed the correct ones.
  8. maniac
    maniac
    Shouldn't use them, early Chevy springs are 2" wide, lowering block should be 2" wide also.
  9. heavy
    heavy
    Your best bet is to make your own I did.There used to be a guy on here that made'em whatever drop you want(for the narrow spring chevies) if you don't have the tools to do it yourself.
  10. I do believe the correct width on 49/50 chevy;s springs is 1'3/4'' try chev's of the 40's
  11. Don't ya love it when someone posts a question, then there are questions back at him because he didn't explain it well and then he doesn't bother to come back on? Especially when he has impatiently bumped his own thread!
  12. GREASER815
    GREASER815
    It is pretty obvious that he meant there is 1/4" of block hanging over each side of his leaf spring.
  13. devilleish
    devilleish
    My ex-girlfriend bought a 59 Ford wagon a couple years ago with generic parts-store cast aluminum 3" blocks installed. BEWARE. Those blocks fell apart when I took them out. Check the mini-trucker suppliers out. Some sell EXTRUDED aluminum blocks with the pinion angle machined in. Well worth the few extra bucks.
