Technical Lowering front I beam on 37 chev
Discussion in 'Traditional Customs' started by Jdmcrx, Jun 26, 2024.
  1. Jdmcrx
    Jdmcrx
    Hey guys i wanna lower the 37 chev non deluxe I beam and everything i have read was recommend Sids but when i messaged SID looks like he wont be doing them or not for a while.
    Is there any other options to do a front drop axle ?
  2. Dan Hay
    Dan Hay
    No idea, Sid is who I would call, great guy good service.
    Kelly Burns likes this.
  3. guthriesmith
    guthriesmith
    Sid is trying to slow down and isn’t taking orders. He no longer has employees so is the only one doing the work now.
    winduptoy and TrailerTrashToo like this.
  4. poco
    poco
    from oklahoma
    Put the springs under axle instead 0f on top.
    winduptoy and Bob Lowry like this.
  5. Joe H
    Joe H
    There isn't enough room for the axle between the springs and frame rail. '37s used flat front springs, no arch to them, no room! My truck is lowered with different springs I purchased from Detroit Spring, I used longer front shackles to raise it back up some, it would hit the bump stops pretty easy. Dropped axle is your only hope to still have it drivable and look correct, late model independent front will lower it, but then you have a MII.
  6. Paint
    Paint
    I ran this 6 inch drop tube axle from Butch's Rod Shop for many years but I don't know if they are in business anymore. They were in Dayton Ohio.
    Jdmcrx likes this.
  7. Greg Haynes/Ansin axles
    Just.dale, akoutlaw and guthriesmith like this.
  8. Jdmcrx
    Jdmcrx
    this was one of my ideas to put the springs under the axle and make some spacers for the bolts.
  9. Jdmcrx
    Jdmcrx
    thanks guys was hoping to get the front axle done by SID but its kind of looking like i either put the axle over the springs or i go to a IFS flatout front suspension but IFS is alot of work
  10. There’s more than one guy to stretch axles out there
    swade41 and guthriesmith like this.
  11. For about the same amount of planning and maybe less work, you can get if where you want it to be without going to a M2, and its way cooler!
    I completely agree with @anthony myrick
    guthriesmith and anthony myrick like this.
  12. The issue with flipping the from axle is how much closer the axle is to hitting the frame.
    guthriesmith likes this.
  13. Dan Hay
    Dan Hay
    I just finished an IFS on a 38 coupe. I have a thread in the off topic section because IFS is not allowed on the main board. It’s not too bad, I did a bolt in ch***is engineering crossmember and speedway components. I can advise if you’d like. My thread is called “Family Heirloom 38 Chevy”
    winduptoy and vtx1800 like this.
  14. Mr48chev
    Did you ask Sid if he had an axle in stock that he would sell? From what I read in his announcement on FB he intends to just do a batch of axles at a time to haul to swap meets and sell and be able to have personal time and travel for fun in the mean time.
    Kelly Burns and winduptoy like this.
  15. swade41
    swade41
    from Buffalo,NY
  16. K13
    K13
    Contact Lee at LG Speed & Customs in Victoria. He drops axles. Keeping it in Canada will reduce the cost immensely.
    His email is on his facebook page or he is on Instagram as well.
    Jeff Norwell and winduptoy like this.
  17. Jdmcrx
    Jdmcrx
    Thanks just sent them a email hope they can might be cheaper in canada but not sure lol
    Dan Hay and winduptoy like this.
  18. K13
    K13
    There are at least 2 guys on the island that drop axles so one would think there must be someone in Ontario that does it. @Jeff Norwell?
    Jeff Norwell and Jdmcrx like this.
  19. Jdmcrx
    Jdmcrx
    Someone in ontario would be a big bonus :)
  20. verde742
    verde742
    I HAVE A FRIEND WHO DROPPED HIS OWN, I AM SURE HE WOULD DISCUSS IT WITH YOU
    THEY JUST DID IT TO SEE IF THEY COULD, NICE JIG, GREAT JOB PERFECTION.
    HE IS ON HERE, HE AND HIS KIDS, NICEST PEOPLE YOU WILL EVER MEET .
    I USE CAPITALS, SO I DON'T HAVE TO WEAR MY GL***ES. (I AM NOT YELLIN' )
    HIS NUMBER IS 360-425-5092
    Kelly Burns, Andy and seb fontana like this.
  21. seb fontana
    seb fontana
    from ct
    MY EYES THANK YOU!
    Andy and Johnny Gee like this.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Unfortunately the fella I knew has p***ed on But.. I would contact my pal Keith at BinBrook Speed and ask him.(BinBrook Ontario)
    I think he may send his work to @thunderbirdesq .....
    I would DEFINITELY send the axle out to Lee at LG Speed and Custom... great work and Rep.
    K13 likes this.
  23. Jdmcrx
    Jdmcrx
    Spoke with LG only does FORD axles :(
  24. @Dan Hay did your car have a dropped axle before you went to IFS? If so, maybe you would like to sell it to @Jdmcrx ?
  25. Dan Hay
    Dan Hay
    No, it had a 39-48 Chevy kingpin IFS. It sat real high with that setup. I had it in the cl***ifieds for months and finally s****ped it.
  26. K13
    K13
    The other guy on the island that drops axles is Victory Rod and Custom. Not sure about contact info for them but they are on Instagram. May be the same situation as Lee though.
  27. Dan Hay
    Dan Hay
    Maybe look into a universal axle they make for g***ers?
    WAC custom axles makes made to order solid axles. Might be worth checking out
    Budget36 likes this.
  28. guthriesmith
    guthriesmith
    Also, @Jdmcrx did you ask Sid if he by chance had one sitting on the shelf? He isn't taking orders for new stuff, but is still in business and does have some stock. I was just there Monday evening and asked about a 57-59 Chevy pu axle that I have a buddy looking for...and he had one...
    Dan Hay and anthony myrick like this.
  29. Dan Hay
    Dan Hay
    I feel like I should buy a 35-40 Ford axle from Sid just to have one in stock for the next car that will inevitably need it
  30. I had about the same thought.
