Using What I have, and trying to keep the car as much an A' as possible I need to lower the rear of my car. I have a hopped up A' driveline. Engine trans and rear. Ideas In motion include a Reverse Eye Spring and I don't want to Z the Frame. I am thinking of removing or swapping Leaves around How has this effected the spring rate/handling? Has anybody ever lowered the Spring Perches on an A Axle? I'm only looking for about 3-4 inches of drop total, to get it more in-line with the front. How many leave do you think is a good idea to remove. I have an 8 leaf spring.
I don't know how you could lower the spring perches, you're just clearing the axle as is. A Model T spring is the usual step in lowering the rear
Try the search menu. This issue has been covered countless number of times over the years. Every possible way to do it has been covered several times.
