Lowering my 1950 chevrolet styleline deluxe
Discussion in 'The Hokey Ass Message Board' started by Rock Island Rocket, Jul 10, 2011.
  1. Rock Island Rocket
    Rock Island Rocket
    Looking for advise on ways to lower my styleline, do not want to put it on the pavement, just looking for a better stance than stock, something I can do without alot of work or money!
  2. walls
    walls
    No matter what you do, it will require some work.
    You can take your front springs out and cut them. Or for about $100 or so, you can get some 3" lowering springs. I think it's worth it.
    For your rear springs, you can have them re-arched or buy a set of lowering springs for about $300-400. Again, if yours are worn, it may be worth it. Expensive though. Obviously, lowering blocks can be used with or without lower rear springs depending on how low you want to go.
    At the end of the day, it can cost you $0 or $2000 depending on how you do it. Plenty of info here if you search for it.
  3. Lone Star Mopar
    Lone Star Mopar
    Dropped uprights / steering arms and new springs up front. New leafs, shocks and maybe blocks and a notch out back if youve got the dough. Or stepped A arms and cut coils if your a good welder and on a tight budget. Then use 3 inch blocks and pull a leaf out back add some air shocks and the ride is sill reasonable. Remember, it takes doing some work to save some money so dont be afraid to get dirty.. That should get you looking a whole lot better. Much more than that requires some more serious work on these cars. Lots of different techniques have been covered here before if you search around a little. Good luck, post some pics when you get done!
  4. Rock Island Rocket
    Rock Island Rocket
    Thanks for the help guys! Where can i get the lowering springs?
  5. 49ratfink
    49ratfink
    just load it up with fat chicks.
  6. walls
    walls
    I'm sure there are other places but I've bought twice from Jamco. They're slow so don't expect to get them quickly. They make nice stuff though.
    Or just load it up with fat chicks.:)
  7. NORTH30FORD
    NORTH30FORD
