Lowering my '57 chevy... QUESTION
Discussion in 'The Hokey Ass Message Board' started by HeX, Dec 23, 2003.
  1. HeX
    HeX
    Want to lower the '57 a little (maybe 3-4" in the rear and a little less in the front)... Been lookin' at a couple of different options and the best solution I can come up with is to get taller shackles and remove a leaf or 2...
    If this is not the best way to go please give me another solution... (thought about flipping the axle but I will only have 2" clearance if I go that route)
    If this is the best solution which leaf(ves) should I remove?
    Also, what should I do to treat the leaves before I re-install them?
    Thanks.
    Tim
  2. HeX
    HeX
  3. HeX
    HeX
  4. johndanger
    johndanger
    flip the rear axle and c the frame , dropped axle up front, or if you are trying to save $ flip the front axle too , or chanel the bed and cab
  5. HeX
    HeX
    Definitely want to save $$$ but want to do it right too...
    Can't flip the front... If I do the oil pan will only last to the first pot-hole...
    As for the rear, if I flip it and "c" it I don't think there will be enough clearance for full travel... That's why I came up with the solution of extended shackles and losing a leaf or 2...
  6. zman
    zman
    from Garner, NC
  7. Simple: Rearched springs and two inch blocks out back, dropped axle up front.
    As far as the clearance issue w/ c'ing, where are you worried about clearance? You can always raise the bed floor a few inches.
