Technical Lowering pitman arm for better clearance
Discussion in 'The Hokey Ass Message Board' started by BrotherJames, Oct 22, 2018.
  1. BrotherJames
    BrotherJames
    putting a GMC 6 into a 1947 plymouth. it's a bit heavier then the old flatty so the pan hits the tie rods,
    my options are to raise the motor (pain in the YNW) or lower the pitman arm.
    Since I am good at welding I have the idea to cut the pitman arm, & lower the part of it that attaches to the tire rods by welding a vertical piece of 1/2 inch steel bar to the cut pieces (kind of like creating a dropped spindle), this would lower the tire rods. BUT would it mess with the geo. of the steering system? That's my question...
    I've welded cast material successfully before so that's not a issue with me.
    Thx. in advance.
  2. stillrunners
    stillrunners
    from dallas
    go for it....a Hemi on one car and a Chevy on another car transplants didn't work with the modified drop steering....but maybe yours will....
  3. rooman
    rooman
    Yes it will mess with the steering geometry. I am not sure why the engine being heavier would change the clearance as the center link on the steering that the tie rods attach to is not affected by the ride height of the ch***is. Only the outer end of the tie rod will move up relative to the frame as the ch***is moves down.
    Roo
    X38 and Unkl Ian like this.
  4. stik70
    stik70
    from midwest
    Is there a chance you could notch the oil pan to create the needed clearance?
    Unkl Ian likes this.
  5. Stooge
    Stooge
    While im not sure how the weight of the engine would effect this, cutting and welding forged pitman arms always gives me the creeps. as much as Im willing to cut something apart, I don't mess around with them, too much chance of something going wrong and too many horror stories to ignore.
    Since you are just getting the engine in place, I would think it would be a lot more efficient to change the mountings, add spacers, etc, for it now and not have to worry about a critical steering component being compromised and possibly failing down the line, as well as not having to correct the steering from what is changed from modifying the pitman arm.
  6. khead47
    khead47
    Your fix is traditional. Was done many times back in the day.
  7. rooman
    rooman
    That does not mean that it is a good thing to do
    Roo
  8. 3banjos
    3banjos
    from NZ
    I totally agree. That sort of thinking is straight out of the R-rod encyclopaedia. Without searching, maybe a dropped pitman arm is available for your application.
    Atwater Mike likes this.
  9. Unkl Ian
    Unkl Ian
    Steering components are forged, not cast.
    Yes, it will **** Up the steering geometry.
    Nobody can figure out why the engine weight created a clearance problem.
    Take that as a clue.
    Stooge likes this.
  10. Unkl Ian
    Unkl Ian
    People used to do a lot of dumb **** way back.
    And it is still dumb.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Sounds like a bad idea to me, they are available in many different lengths. HRP
  12. Mike51Merc
    Mike51Merc
    FYI, welded steering and suspension components are illegal in a lot of places. I wonder why?
  13. alchemy
    alchemy
    If they are forged they can be bent. How much drop do you really need?
  14. proartguy
    proartguy
    from Sparks, NV
    Raise the engine. I would think a GMC 6 would not be a good fit in that engine compartment as they are rather small in ‘40s Plymouths.
  15. Atwater Mike
    Atwater Mike
    Actually, a 331-392 Hemi fits rather well in there. Wide, but otherwise, compact.
    Is the Jimmie going in for shock value?
    1. Notch the pan.
    2. Raise the Jimmie.
    Don't weld main steering components, especially on the South end of the worm!
  16. proartguy
    proartguy
    from Sparks, NV
    I guess I should have been more precise. The length of the engine compartment is short. I know from putting a 318 in one the firewall has to be dinged a little to move the engine back to allow the pan to clear the tie rod. I imagine a GMC is a lot longer and will require firewall mods to fit well.
    The dropped tie rod modifications were not done on the idler or pitman arm in “traditional” days and usually resulted in limited steering.
  17. Unkl Ian
    Unkl Ian
    Raise the front of the motor to get the clearance you need.
    And/or, modify the oil pan.
    rooman likes this.
  18. gimpyshotrods
    gimpyshotrods
    Raise the engine and trans.
    rooman and Unkl Ian like this.
  19. Kerrynzl
    Kerrynzl
    If you lower the pitman ,I ***ume you are also lowering the idler on the other side as well [ dropping the whole drag link ]
    If you do this you will also need to bend and lower the steering arms to correct bump steer issues you will create.
    Google image "Bump Steer Geometry" You'll understand.
    You can get this close enough with a string line and draw crosses on the ball joints.
    rooman likes this.
  20. jimmy six
    jimmy six
    I can garentee you any pan you are using can be cut which is what I would do. Up near the front it only needs to clear the con rods and once your clear the tie rod slant it back on a 45* angle. It can also be flat. The pickup is in the rear. A pan gasket is all you need and if it wasn't glued on both sides u won't need it. Only some rtv in the corners.
  21. Unkl Ian
    Unkl Ian
    If the OP doesn't return, do we ***ume his steering failed and he died ?
  22. mickeyc
    mickeyc
    You say cast? I am thinking pitman arms are forged? If the arm is indeed forged,
    it could be safely welded by a competent craftsman using proper beveling and compatable
    metals and welding techniques. It would then need to be dye pen or xray tested to insure
    weld integrity. Welding cast steering components is something quite different, and I would
    not be inclined to do so.
