lowering shakles
Discussion in 'The Hokey Ass Message Board' started by 55 gasser pickup, Jun 6, 2011.
  1. 55 gasser pickup
    55 gasser pickup
    from utah
    Anyone use these I found some for my 55 chevy pickup.I want to lower the rear of my truck a few inches and I am wondering if this is the way to go for a cheap *** like me.I know I could remove a leaf or two but this seams so much easyer to me.I don't haul anything in it so I'm not worried about it bottoming out or anything.thanx for the opinions guys
  2. 40FORDPU
    40FORDPU
    You may be refering to "lowering blocks", these are used commonly, and come in different sizes. "Shakles" were a common item to raise the vehicle back in the sixties and seventies..giving it a rake (jacked up in the rear look)..thankfully they seem to be a thing of the past these days.
  3. 55 gasser pickup
    55 gasser pickup
    from utah
    Ya I know what your Saying mine is raked now that's what I want to fix.I found these on the brothers trucks web site they are shakles not blocks.
  4. ShastaStyle
    ShastaStyle
    from Nor-Cal
    On our chevy trucks the longer shackles do lower the truck, not raise it. It depends on whether the springs are above or below the axle. I have lowering shackles along with a few leafs pulled out of the back on my truck and if you don't plan to haul anything you'll be fine. You can nab the 2" shackle "kits" on evil bay for $49.
  5. squirrel
    on those trucks the shackles being longer will lower it. Blocks would raise it.
    Watch the pinion angle....
  6. 55 gasser pickup
    55 gasser pickup
    from utah
    I wouldn't mind raisig the front just al ittle to give it a g***er stance.I think I will go with shackles for the rear.and see how it sits without removing any leafs.I don't know what to do with the front I don't want to put blocks to raise it.
  7. 55 gasser pickup
    55 gasser pickup
    from utah
    Sorry about the ****ty typing skills I'm doing this on my blackberry
  8. Ohio Rodder
    Ohio Rodder
  9. 55 gasser pickup
    55 gasser pickup
    from utah
    Thanks for all the help guys
  10. ShastaStyle
    ShastaStyle
    from Nor-Cal
    The shackles in the rear will definitely help you get rid of the stink bug stance on a budget. Performance Online (POL) has the shackels for $49. On the front suspension the most inexpensive option is to pull a few leafs from the spring pack. If you can spend a several hundered bucks you can buy lowering springs or a drop axle.
  11. 55 gasser pickup
    55 gasser pickup
    from utah
    I said I wanted to rais up the front a little maybe 2 inches if that for that g***er look.but ya the shackles will be enough for the rear I think.I just don't want blocks on the front.just an idea I will lower the rear first for sure.
  12. derbydad276
    derbydad276
    on fords you can flip the front spring hanger I dont know if you can on a chebby
  13. 55 gasser pickup
    55 gasser pickup
    from utah
    I will get under it and look when I get home.I wonder if I can get the springs rearched?.how much does that cost?
  14. The Internet
    The Internet
    from Hudson, NH
    If you pull a few springs from the rear and add them to the front pack, you would probably get the look you're after. You would only need to buy new U-bolts.
  15. 55 gasser pickup
    55 gasser pickup
    from utah
    I thought about that.I might try it because it don't ride like a caddy anyway.well see how it is when I lower the rear and then decide.
  16. rusty1
    rusty1
    ....my 55 p.u. had lowering shackles, I wanted it lower, so I flipped the rear hanger to the top of the frame so the shackles hang down, then used lowering blocks on the rear axle which is now on top of the springs...like this...
  17. ToDieFor
    ToDieFor
    from MN
    Hope you replaced that tire too... :D
  18. rusty1
    rusty1
    ..those tires are my mock-up wheel/tires, been used on dozens of cars/trucks..good eye tho,
    I was wonderin if anybody would say anything about em.
  19. 55 gasser pickup
    55 gasser pickup
    from utah
    I will see how I like it with the shackles and go from there.I really don't want to get that involved with it because I'm going to be selling it.but I want to drive it for a few weeks first.thanx for the ideas
