Projects Lowering Shoebox Ford
Discussion in 'Traditional Customs' started by Slow 50, Dec 10, 2014.
  1. alchemy
    alchemy
    You do understand that it doesn’t really matter what other people do? You need to make sure that the angle of YOUR pinion matches the angle of YOUR transmission yoke. If the trans is 4 degrees down (arbitrary number there), then the pinion needs to be at 4 degrees up. Or whatever degrees your transmission is.
  2. This is a lot like Follow the leader. If you don't know where he's going you can end up somewhere you don't want to be. In your case you need to be doing your own Math. "Just Like Him" doesn't mean it's going to work for you. In fact, doesn't mean his works for squat either.
  3. You are right I just need to get under the car and find out for myself.
    Pist-n-Broke likes this.
  4. I figured 49-51 required same measurements, thank you guys for the pointers I'll get under her and see what's up and get back to you guys after to let you know how it turned out
  5. 50 Merc Man
    50 Merc Man
    Sits nice
  6. 50 Merc Man
    50 Merc Man
    Definitely changing rear tires is a problem!!
    Rear shocks have to come off just to change a tire!!! Real pain in the ***!! I even tried letting all the air out of it and still couldn’t pull em off.
    You should consider bags down the road, I know I am
