Technical Lowering the '41 Chev
Discussion in 'The Hokey Ass Message Board' started by soddruntlestuntle, Apr 1, 2015.
  1. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    In the next month or so, I want to see about lowering the ride height on my '41 Chev coupe. I'm on a very tight budget, so no hydraulics/airbags. I also don't want to torch the existing springs as I'd like to be able to return it to stock if the need ever arises. Was thinking about a set of professionally-modified front springs from Coil Spring Specialties in front, and a simple set of blocks in the back. Anyone have any thoughts or alternative suggestions? Advice?
  2. hinklejd
    hinklejd
    from Fort Worth
    Blocks in the back are not going to work - look at where the spring bolts to the axle. There is a pivot between the spring and the axle - if you want to drop it some, you're going to need two new leaf springs for the back and shorter springs for the front.
    Or you can grab a set of skirts and just make it appear lower while maintaining yur ride height.
  3. 48 Ragtop
    48 Ragtop
    soddruntlestuntle likes this.
  4. jcmarz
    jcmarz
    from Chino, Ca
    Don't listen to hinkiejd. Lowering blocks can and have been used on Chevy cars with torque tube rear axles for years. If you're on a budget, just remove one coil turn from the front coil spring with 3 inch blocks out back.
  5. You can flip the main leaf at the rear, and use the front lower spring mount extensions (you will have to drill out your rivets and replace with HT bolts. All can be unbolted and can be returned back to stock, no need to cut springs.
  6. jcmarz
    jcmarz
    from Chino, Ca
    Don't use those blocks for the front. Cut one coil, buy a lowered coil or/and spindles. And don't use homemade blocks .It boils down to common sense,Safety.
  7. NashRodMan
    NashRodMan
    Sod,
    I lowered my 41 Chevy in the back with 3" lowering blocks (and original drivetrain and suspension) and it worked out pretty well. And the blocks are narrow to match the narrow springs which these cars have (i.e. only 1 3/4" wide). Now and then I would bottom out on the axle with p***engers but I think that was because of weak springs. I have since replaced the whole drivetrain and at that time I bought the Ch***is Engineering rear spring kit. That works wonders but is a budget killer (over $600). Anyway, I also bought the front lowering kit from Butches Cool Stuff which lowered it about 1 1/2 inches. Some guys get 2 1/4" drop out of it. And, yes you could cut the coils to get it lower. My avatar is with the original suspension with the lowering blocks and front drop kit. Drop spindle are an option but also expensive. My rear drop kit is available if you are interested.
    Paul
  8. 302GMC
    302GMC
    from Idaho
    You don't want to spend a lot ? '41 - '48 springs aren't hard to find, so buy a used set, cut 2 coils off & have a spring shop dearch the rears 3''. Pull the factory springs out & replace ... you now have a traditional lowered car which can be returned to how you got it ... you'll also want to build some mounts for tube shocks as your Delcos are most likely used up.
    Soon, the "2 coils is too much" bunch will check in ...
  9. ol-nobull
    ol-nobull
    Hi. I am posting the web link to Butches Cool stuff. He has lowering kits for both front & rear for your Chevy. I have been looking at them for my 46 Chevy Coupe. My new tires are supposed to be in today & once I get them mounted I will be able to tell if & what I need to have correct stance as I have larger tires going on the rear.
    http://www.butchscoolstuff.com/
    Jimmie
  10. BarryA
    BarryA
    Are the spring 'cups' riveted to the lower A-arm (as they were on my '47)?
    If so you can drill them out, make up spacers - about3/4" should work - I went 1" and it sat a little too low - then bolt it all back up with some Grade 12 bolts.
  11. ol-nobull
    ol-nobull
    Hi. Yes it is riveted so you method should work great. Those at Butches are nothing but expensive spacer bars.
    As an aside I got my tires on yesterday & put the Coker 600r16 cl***ics on the front and the Coker 700r16 on the rear using a bit wider wheel for the 700's and amazingly the stance came out perfectly level. I do not need to lower the car for stance and if you look at my avitar you can see my height & at age 76 I have to do enough scrunching down to get in the coupe anyway.
    I want to tell you that thedifference in the ride & handling between the old Allstate Bias ply tires & the Coker cl***ic radials is tremendous.
    Jimmie
  12. Scooterville
    Scooterville
    I have lowering blocks on the rear of mine, and up front I have stock coils from a 47 chevy that I cut 2" off of.
  13. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    Scott, how do the cut coils effect the ride? I've read that it will make the ride much worse, yet I met a couple at the show I was at Friday, who also owned a lowered '41 coupe, and they cut their coils and said it rode fine. Your thoughts?
  14. gatz
    gatz
    Where do you get Grade 12 bolts?
  15. Scooterville
    Scooterville
    The ride feels fine to me. I cut 2" inches of spring which dropped it about 4". 3 or more inches cut from the spring may affect the ride.
  16. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    That's great to hear-- I really didn't want to shell out $200+ for a set of custom springs... stupid question, but as a Noob in the Kustom World I have to ask-- did you take a hacksaw to your springs, or cut them with a torch?
  17. Hot Rod Cowboy
    Hot Rod Cowboy
    I'm no expert for sure, but I think the heat from using a torch can take the "spring" out of spring steel. I'm sure lots have done it that way.
    Personally, I'd use a cutoff wheel.
  18. Scooterville
    Scooterville
    I used cutoff wheel to give it a nice and clean cut.
  19. BarryA
    BarryA
    I guess there is a difference in the naming, where I am bolts use the codes: 4.6; 8.8; 10.9; 12.9 as a measure of strength
  20. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    Okay, freshly-cut used set of coil springs, check; 3" lowering blocks (thank you NashRodMan!), check. Forgive me, but the last thing I lowered was an '85 Toyota pickup-- anything I need to be worried about as far as this Chevy goes?
  21. jcmarz
    jcmarz
    from Chino, Ca
    Running out of gas. Post a photo of your lowered 41
  22. NashRodMan
    NashRodMan
    Nope. Piece of cake. YouTube and Google are your friends!!
  23. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    By gum, I hope you're right. We shall find out this weekend.
  24. Check clearance between top of tie rods and the bottom of the tin panel which is bolted to your ch***is. Then get someone to bounce the front end up and down while you watch. Best done in a pit..
  25. NashRodMan
    NashRodMan
    Not too much to it! Here's proof! :) Just be careful and keep your fingers out from between metal things like springs and frames!!!
  26. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    Well, we're half way there. Did the rear first due to time constraints Saturday. Thanks again NashRodMan, other than a couple of stubborn nuts, installing the blocks went off without a hitch. Praise the Lowered!
  27. NashRodMan
    NashRodMan
    Looks great in the back. You should cut a coil (or more) out of the front springs.
  28. NashRodMan
    NashRodMan
  29. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    Thanks. Have a set of freshly cut and painted springs ready to go-- probably Thursday.
